Question about OKI B6300n Printer
Oki b6300 close cover a
I am getting this message "Close Cover A". I just had a basic paper jam, i cleared it and after that i got this message. The cover closed but cannot figure out where is the problem. Please help!!!!!
4 Suggested Answers
  • 21 Answers
SOURCE: oki b6200 paper jam
restart the printer or reinstall driver again.
Posted on Oct 08, 2009
romeetb
  • 66 Answers
SOURCE: error message stats
a very usual problem steve. try removing power to the printer and let it stay idle without power for abt 20-30 minutes and then try again.this should clear the error message from the memory.
Posted on Feb 04, 2010
  • 3 Answers
SOURCE: My OKI B6300 printer have
There are several reasons why this error keeps coming up, and seeing the date I will assume that you fixed it. But for those that are looking for the solution:
Sometimes it is caused by the feed rollers not picking up the paper - remove the trays and replace the rollers ($30 kit) both in the tray and in the printer.
Sometimes it is caused by a small piece of paper jammed in works somewhere. Remove all trays, turn it on its side and use a flashlight to look around. It really doesn't take much to mess it up.
Take a look at the tray roller and make sure it is spring loaded. If the spring comes out or the retarder breaks tis will cause misfeeds as well.
Posted on Feb 15, 2011
OKI b410d error 382
That is a paper jam code. Reopen the cover, and clear all paper jams. Close the cover, and then I would reset the machine by turning it off and on if the code continues. http://www.german-parts.de/oki_manual/paperjam/stau_b400_series.pdf
Feb 05, 2015 | OKI B Office Equipment & Supplies
Text on the display: back cover open,close the Back Cover we close the cover but no results
If you turn the printer off and then back on when there is a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Feb 25, 2011 | Brother MFC 7420 All-In-One Laser Printer
Dear Sir(s) I have an OKI data OL400e the problem is "Message --Cover open" even i close it well Please advice Thanks
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Feb 11, 2010 | OKI OL 400e Led Printer
Error message stats 'pull out trays clear jam, close cover A. but can't find any paper in machine and cover a is closed
Feb 04, 2010 | OKI B6200 Laser Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Oki b6200 paper jam
Have you checked to see if there is any paper jammed in the sensor, at the back in the 150-sheet feeder assembly, if not the paper could be stuck the 150-sheet assembly
Feb 26, 2009 | OKI B6200 Laser Printer
My OKI B6300 printer have problem: "pull out all trays, clear jam" & "clear jam & close cover A" These 2 screens keep alternating. I am familiar with saying, "clear jam & close cover A" because I had...
Feb 12, 2009 | OKI B6300n Printer
Paper Jam
Open the tray and cover. Look out for any paper inside the cover.
Close the cover and tray firmly. Then check for a test page.
Let me know if I can assist you further. Don't forget to vote the solution.
Regards
Ellin
Sep 25, 2008 | Dell 924 All-in-One InkJet Printer
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
OKI B6300n Printer Logo
399 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
