Question about Craftsman Garden
Power Washer Will Start but not Run
I have a Sears preasure washer with a Tecumseh engine. I would not start and I took the nut from the bottom of the bowl off and it was clogged. I got the info from a video I found on the web and the guy said to be sure and clean out a hole that was at the top of the injector but all I could find were two at the bottom and the one inside. Put it back together and it will start with the gas from the prime but will die in just a few seconds. I took it off and it was clogged again but I din't see trash in the gas. Cleaned, reinstalled and tried again but got the same results. Could thie injector be bad?
  • raymondashwo Jun 05, 2009
    Hello Mowerinfo,
    Thanks so much for your reply and it was helpful as I had not thought about trash, I removed the gas tank and emptied it into a glass jar but could see no trash. I removed the carb bowl and made sure I did't spill the gas and I could see little black specs in the gas. So where was it coming from? I removed the carb completly and looked at the main nozzel tube and it seemed to be off center. I looked in the throat of the carb and could see the nozzel was sticking out about 1/4 inch so I took a small screwdriver and pressed it back down. When I did a small piece of the tube and the O ring fell out the bottom. The nozzel has two rings around the bottom part and it was broken at the bottom of the second ring. The O ring was quite deteriorated and I believe pieces of it is what I'm seeing in the carb bowl. Had to stop at that point and ordered a carb kit and hope to rebuild it this weekend and will be very happy if it fixes it. I also finally found the third hole in the bowl nut I wish it had just been trash in the gas but without your suggestion I don't know how long it would have teken me to figure it out so thanks again for your reply.
    Problem Solver:
  • 8 Answers
Hello.....sounds like you might have debris in your fuel as well..... need to take off the carb and gas tank....let the fuel from the gas tank (fuel line still attached) run into a jar and check for debris and/or water in the gas....is you see that, get rid of the gas in your mower and your gas can, then buy new gas and a gas can (if metal...could be rusted)....second....take the fuel bowl off the bottom of the carb, careful to save the gas to check for debris / water (this also helps indicate the quality of your gas)....clean the bowl nut with fuel ports (3) and the injector port inside the center post which the bowl nuts threads into.....use carb cleaner to make sure all is clean....use a small wire to assist cleaning if necessary....also remove the float and needle valve....careful to note the assembly to reassemble....and clean with carb cleaner the valve area as well....this will insure all debris is clear.....reassemble the carb and gas tank....this should clear up the problem....
Posted on May 27, 2009
  • MowerInfo Jun 06, 2009
    hello again......happy to help...make sure you don't use any fuel with more than 10% enthnol becaue any higher amounts will destroy your rubber gaskets......and clog your carb again....also....make sure you clean good or replace your fuel hose from the tank before you reassemble it to the carb.....
I have a Tecumseh vertical shaft (TVM195 1502630 (C) )electric start engine, would like to change it to recoil start, what parts do I need?
Will try to answer your question.First your shroud cover that cover flywheel. Does it have threaded holes to bolt recoil on it. If not you will need to find a donor engine the same size. On donor engine remove shroud then remove bolt holding flywheel there will be a washer and recoil cup remove both. Remove other shroud and safety screen then flywheel nut and install donor parts the same way and should be all you need to do. One thing... Check flywheel for locking hole or slot for recoil cup so it does slip when pull recoil cord. If there is no way to do this you will need to change flywheel too.But if there is no teeth for electric starter you will lose that option altogether for electric start if you want both.
May 11, 2016 | Tecumseh Garden
My washing machine wont start,its opening and turning on, all the lights are on but it wont run. Can you help me please
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
A broken washer means disaster in most homes which is why we've created this repair guide to help you fix a washer that won't start. While a washing machine ...
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't fill, start or run ... Front Load Washer Won't Drain or Spin Video: Washing Machine Tips from Sears ...
Troubleshooting a Washing Machine That Won't Start ...
www.doityourself.com/.../troubleshooting-a-washing-machine-that-wont...
If your washing machine won't start, begin by looking at the power source. ... mywashing has filled with water,now it wont agitate,it's like it is dead,could this be ...
Jan 14, 2016 | Washing Machines
Have a tecumseh ohh50 4 cycler engine on a garden
Check for condensation in the tank. Fill with FRESH gas, then if no luck, proceed ...
Main jet partially blocked. Undo bowl nut. Some models have the jet in the side of the nut - check and clean. If not, the jet is in the emusion tube of the carb - accessible throught the bowl nut orifice. Clean out & test.
Jul 23, 2010 | Mtd Garden
I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Nov 07, 2009 | Craftsman Garden
4.5hp tecumseh won't start. replaced sparkplug and air filter and still won't start. Used starting fluid and started up but then quit.
I have a Sears Craftsman Vacuum/blower with a 4.5 Tecumseh that wouldn't start. I removed the screw on the bottom of the float bowl and cleaned both the bowl and the screw. The screw has two small holes on each side which feed gas through the middle of the screw up into the carb. There was gunk which had clogged the holes and therefore no gas was getting to the carb. Once cleaned and reattached, the engine ran fine. Unfortunately, I also took the air filter housing off the carb and one of the two screws stripped while putting it back in. Be careful when threading any screws.
Sep 16, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have an old pressure washer that uses Tecumseh H30 engine. After pumping the choke bulb on the carb, it will crank, run maybe 5 seconds and quit. Thanks
When you get it started, move the choke to the middle, then let it warm up. you might have to move the choke back and forth until it warms up, keep the throttle wide open.
Jun 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Jun 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Kenmore elite HE3t 2004 washer quits during spin with f11 code
Under the bottom panal (after you remove it) look to the left towards the middle and you will notice a white box looking part, this was our problem and sears ended paying 100% of parts which run about $215 before labor, this is a very easy fix and my husband replaced that and also our control buttons all werent working which sears also paid for 100% after much bickering over the phone and the service man taking care of it for me! it took him about 20 min to do both parts and our washer is working like a pro again! Our washer is the HE 4T and was flashing the F 6 AND F11! this is a lemon machine and sears should realize it and actually take care of its customers! i did notice a class action law suit on this machine and i have emailed the attorney taking care of it,
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE Washer
problem started when washer started itself up twice in the middle of the night....after that the washer seems to have problems figuring out what it wants to do...when running a wash it will start, run for 2 minutes then start scanning numbers...it does not land on a code...it will spin, stop, start...sears has replaced the mother board 3 times....and we will be phoning them again as it has not fixed the problem..one other time it did not spin properly and clothes were wet...we have a dedicated surge protector on it...we have had our electrical checked and no problems there...sears confirmed that as well..the techs have given up on it and don't know what to do with anymore...it is still under warranty and now costing sears more to service it then replace it....time for them to do the right thing and "take it back"...very disappointed in this washer...wish me luck when i call them again...they must be sick of hearing from me....lol
Apr 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Garden Logo
180 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
