Question about Kenmore 51572 / 51574 Side by Side Refrigerator
My freezer defrosted and refrigerator is not cold.
Model No. 51554 103 My refrigerator is not cold and the freezer defrosted. I hear the fan running.
fridgetech
  • 473 Answers
SOURCE: Kenmore 65092 Refrigerator
This fan will be running anytime the compressor is running. If it isn't then it has failed and will need to be replaced.
Posted on Nov 12, 2007
SOURCE: Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Posted on May 23, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
  • 1462 Answers
SOURCE: side by side kenmore refrigerator
defrost system not working. take back plate off freezer. checkdefrost heater and any stats mounted on the pipework
Posted on Sep 10, 2008
My freezer is not blowing cold out. I hear the compressor running but its not getting cold
most likely bad evaporator fan motor located behind the wall in the freezer,when you open the freezer door you should hear the fan blowing in the freezer unless it's in defrost,if you don't hear it check it in 45 minutes if still no fan it's bad.
Oct 03, 2014 | Frigidaire FRS3R5EMB Side by Side...
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
Model 106.9630280 The freezer is working but
you probably have a bad air circulation fan or a restriction in the ductwork between the freezer and the refrigerator that the circulation fan supplies the cold air from the freezer to the refrigerator compartment. you should be able to hear the circulation fan motor running when the unit is in normal operation mode. the only time the fan will not be running is when the unit is in defrost mode which occurs once every six to eight hours depending on the defrost timer in your unit.
Mar 14, 2010 | Refrigerators
Refrigerator was not cold, now freezer is not working either
You hear a fan running - but do you hear the compressor motor running too ? Common problems are defrost timers and refrigerator being stuck into defrost - or control board problems or faulty thermostats - Those defrost timers tend to go bad more frequently on newer refrigerators compared to the older refrigerators !
Aug 17, 2009 | GE Refrigerators
Kenmore 21 refrigerator not getting cold - freezer still pretty cold (top) - perhaps not all the way
you have a defrost prblem or a leak in the sealed system.if you see frost built up on back freezer wall then it is a defrost problem also check evaporator fan motor to see if it is running.if machine is in defrost you wont hear it.so when compressor is running see if fan is running.
Mar 06, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer and refrigerator will not get cold - fan runs but not ver
You will need to check for frost accumulation in the freezer section. The rear panel inside the freezer will need to be removed. If there is frost either the defrost bi metal or the heater are open. If both are ok the defrost control needs to be replaced depending on the model some defrost controls are electronic some are mechanical.
Dec 26, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE SIde By Side - No cold air on the freezer side.
Do you hear fan running in freezer? Should be on when you hear that external fan. If not, you may need an evaporator fan motor. Also check board in back for burned resistor. May need to replace both.
If that fan IS running, remove lower rear wall of freezer and inspect the defrost heater. It's at bottom of coils. It has a wire leading to both sides. Remove with 2 screws and check for continuity. If open replace defrost heater. This is a common failure on these.
Nov 18, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 51572 / 51574 Side by Side Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
