Question about Sony Ericsson W890i Cellular Phone
Cellphone does not ring, or message tone
Done all the settings as per the book, music players works fine but the phone just doesnt ring or the message tone does not ring. Have reset phone, still nothing
  • 36 Answers
Well you say that the music player is working..so there isnt any problem with the speakers..I suggest you better check de settings -> tones -> incoming call ! or settings -> tones-> incoming msg..check as they maybe switched off..that is de only possiblilty that i think maybe the problem..
Posted on May 25, 2009
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
How can i change the "ringtone's message" of my corby GT-s3650
Here's how you can change the ringtone/ message tone:
  1. Go to Menu
  2. Settings
  3. Phone profiles
  4. Edit Profile Name (this will be dependent on the profile that you'll use)
  5. Go to the right "New Messages"
If you want them to be personalized per contact, you will need to access the phone book, go to the specific contact then personalize the message tone or ringing tone
Nov 24, 2010 | Computers & Internet
My Samsung B7320 doesn't allow me to select a message ringtone from my Storage Card...i've tried moving/copying the files in storage card to My Sounds but i cant seem to see any of them there...how to...
first you can try going to your settings and selecting phone settings then go to connectivity and then select usb mode click on media player tab. then u need a usb cable plug it in to ur phone and your pc then transfer the songs from your your storage card to your media player then remove storage card and transfer songs from media player to phone they should automatically b sent to your music folder in your audio section of your my stuff folder from there you should be able to select it as a message tone. if that doesnt work you can try one more thing. you can send the vibration feature to your storage card and it should automatically associate your music with the vibrate feature then set your messag tone to vibrate 7 ring and pick a tone to go with
Jul 24, 2010 | Samsung Omnia Pro B7320 Smartphone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Help using installed ring tones on my nikia 6085
profile ---general---personlize----ringtone(chose the tone from the music folder not received file) -done
May 11, 2009 | Nokia 6085 Cellular Phone
I cannot use my mp3 music to personalise my contacts
It is possible that you may not have your contacts stored on the phones memory but on the sim card instead. Most additional phonebook functions, like assign photo to callers and speed dials will only work if the numbers are on the phones memory. Try copying them onto phone (if not already) and see if that solves it?
Also if numbers are on the phone, check to see if the phone is looking at phone book on the phone or sim? In phone book settings I think there is an option to switch? Hope that helps?
Apr 24, 2009 | Nokia N96 Smartphone
LG Viewty mp3 file problems
I had the same problem but fixed it by transferring the desired mp3 file to the phone memory instead of the memory card. Apparently some mp3 files saved on my 4G memory card, although they worked with the music player, could not be used as ringtones (Invalid file error). This may be one problem with using a 4G card on the Viewty.
Dec 14, 2008 | LG KU990 Viewty
NEED TO CHANGE RINTONE AND HAVE LOST BOOK
not sure if this will work but go into downloaded ring tones pick one see the options and see if it says set as ringtone or message tone it should work also try going into profiles and perzonlize and go to ringing tone and pick downloaded tones hope that helps
Jun 30, 2008 | Palm Treo 500 Centro
I have a 6600 nokia phone..
1ST U FOMET UR MOBILE AND MMC AND THEN INSTALL MP3 SOFTWARE.
Feb 29, 2008 | Nokia 6600
Nokia 5300 xpress music mobile phone won't ring
did you going to settings and then to tones?
Jan 19, 2008 | Nokia 5300 Grey Cellular Phone
Sony Ericsson W890i Cellular Phone Logo
330 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
