Question about DIGITECH VOCALIST LIVE 2
Digitech rp6 i need the circuit diagram for the digitech rp6 guitar effects pedal, in particular the layout of the power connection wiring in the 4pin din socket. i need to wiire a power supply 2 pin barrel connecter to a 4 pin din plug!
  • gracieandmit
    gracieandmit Apr 25, 2012
    call digitech the will help, I have the RP2000 schematic it has a 4 pin DIN I would suspest the 2 are 1 end and the 2 are the leg I sday it that wawy becuase its AC 9VAC no polatity
    President:
  • 1,138 Answers
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
Posted on May 26, 2009
I have Zoom G1XN ext. My guitar effect just lit "Gn" and can't change to Bank memmory. I need the circuit diagram and service code for Zoom G1XN ext whom can help and send to my email dias.no1@gmail.com
Have you tried to reset the unit? You can do this by holding save button for few seconds while connecting your adaptor to g1x/g1xn. Then the indicator will blink, then push save button again,this will reset your unit into its factory settings
Jul 12, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
Circuit diagram of zoom g1x
G1X circuit diagram is the same as the G1. They differ only on the pedal circuits.
circuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-0.jpgcircuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-1.jpg
Give your email,and I'll send the circuit diagram.
Jun 24, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
A musician friend of mine asked me to take a look at his pedal. Apparently there are issues with it cutting out. I figure it's just a bad lead connection on either the input or output jack, but...
Diagram is NOT likely to help much. Look for bad soldering at the input and output jacks AND by the power input jacks. Also look for cracked circuit board and or lifted circuit etch. Lastly, the pots and the soldering around them may be part of the problem. Most of the mentioned things are 95% of the problem.
May 18, 2011 | Roland Boss ST-2 Power Stack Distortion...
This is for the takamine DI+. Is there a wiring diagram as to how to cable from my guitar to the amp? Basically how do you connect the DI+ using stomp boxes. Also, is their a special cable to use to...
Most of the pedals are daisy chained right from the guitar. The output of the daisy chain goes into the DI box set to ground lift. An XLR to XLR cable goes from the DI box to the amp or mixer. Do NOT try to loop the sends and receives of the amp through PEDALS! The sends and receives are LINE LEVEL which is too high for pedals. The sends and receives are for external effects MODULES and EQ's that take line level. Some of those effect units have a foot switch to turn them on and off.
May 05, 2011 | Takamine Acoustic DI+ Direct Box
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
I need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
DIGITECH VOCALIST LIVE 2 Logo
1,413 people viewed this question
Top DIGITECH Music Experts
Michial Gueffroy
steve cannon
Level 1 Expert
NOEL
NOEL
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
