Question about GPS
The unit will not turn on Even with car power charger attached When attached to the computer the system says the hardware is not known I used it without a problem
  • pjw209 May 25, 2009
    How do I reset it if it will not turn on?
    No nothing happens to the unit
  • 3,230 Answers
You try reseting your GPS as to factory default.
post further comment for more help
Thanks
Posted on May 25, 2009
  • Mukesh Kumar May 25, 2009
    ok..
    What happen when you connect it to computer?
    Is there any response in GPS when you connect it to computer?
    Oh! that means this GPS need a repair (a control ic need to be replaced).
    This also cause complete damage to the GPS.
    only 50% chance that it work again after repair.
    Thanks
I have a M8 dragon touch tablet that will not respond to ANY combination of the power and volume up/down buttons.
It sounds like the electronics have failed and you need a new one.
First though, you need to ascertain that the charger works? You either need to attach a different charger that is known to work to the tablet, or you connect a device known to work to the charger you have.
Then buy an iPad, they are the brand leader for a reason :>)
Feb 23, 2017 | Cars & Trucks
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
Toshiba computer won't turn on even when plugged into the charger.
Test your PSU power supply unit or replace it
One bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps?
Nov 22, 2010 | Computers & Internet
In windows xp sp2 my os did not recocnize my mouse. Previously it was working fine. But from 19/5/2010 it not recognize and when windows start it stuck in the middle of the screen. i tried with three...
Bro it is a normal problem of some hardware component units, depend on its hardware manufacturer. because some of the system units need to plug first all the peripherals before you start-up using the computer unit so that it will analyse and familiarize all the peripherals attach on it during reboot mode.Bro follow this steps. 1.plug your PS/2 or USB mouse connector to its port at the back of your system unit.
2. turn off or restart your system unit. 3. or turn on the system unit if you're using turn off mode. 4. wait while the hardware is on reboot mode till windows logo appears.
May 20, 2010 | Computers & Internet
How do I charge my new iphone 16GB?
Your new iPhone comes with a USB cable and a wall charger in the box. If you don't have a computer, you can plug the wall charger to any socket in your house and connect your iPhone to the wall charger using the USB cable. However, if you have a computer, you can plug the USB cable to any USB slot from your computer and connect it to your iPhone.
You can also charge your device from any iPhone dock, or even those docks attached to your home theater system.
For more iPhone / iPod touch tips, click here.
Feb 12, 2010 | Apple iPhone (16 GB) Smartphone
Unit will not power on.
its probably not the battery, your gps should run even without a battery if the power port/circuit is ok. unfortunately this is a common problem that the usb port gets damaged with this and many other model of magellans gps systems.
if you had it plugged in to the car charger, make sure the green light is on while charging, if its not, you might have a blown fuse in the charger or the fuse for the cigarette adapter in the car.
if the green light is on, try letting it on for a few hours, then try and turn it on. if and when it turns on, you can verify if its charging by going to the system settings then the power option. the battery bar should turn green and move from right to left if its charging. if the battery is slightly low but the bar is not moving left to right, then its not charging.
you can check the charging by using the usb cable provided with your unit and hook it up to your computer to verify if its charging. but i suspect it has a bad power port (usb connector)
i hate to be the barer of bad news, because rarely do i get a good rating for being the barer of bad news, but hopefully you just have a bad charger or a blown fuse in your adapter or car.
good luck
bill
Oct 19, 2009 | GPS
Unit only powers on when attached to base charger
sounds like internal battery is dead, if underwarrenty contact company, if not these batteries are not user changeable u will have to use as is or replace
Jul 07, 2009 | Garmin Forerunner 305 GPS Receiver
Nuvi 205w will not power on when car charger is attached
Would you be willing to sell your unit. If so please contact me at dm4par@zoomtown.com
Thanks
Feb 16, 2009 | Garmin nuvi 205W GPS Receiver
Unit charges on computer but not on car chargers
As per the Tom Tom Experts hte computer USB is meant to charge and the Car charger is only used to maintain the already existing charge. Hope this works
Sep 18, 2008 | Tomtom ONE 3rd Edition GPS
GPS Logo
32 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
