Question about DIGITECH VOCALIST LIVE 2
I need the pin out details of a digitech rp6 guitar effects pedal
My digitech rp6 came with no power supply. however i have purchased a power supply 9vac 1.9A which should be compatible but the input into the rp6 is a 4pin din socket. i have a 4 pin din plug but need to wire the power supply to it.
    President:
  • 1,138 Answers
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Posted on May 26, 2009
Is a Harmon ps0913b 240-au-b power adapter, suitable for a Digitech Live Harmony pedal
Consult the manual for the rating of each power adapter to compare. The units will also have the specs needed printed next to the power input jack, but the manuals will be more detailed.
Sep 24, 2015 | Music
The Digitech Trio seems to be frozen, when I start it the red light blinks slow, after pressing the pedal it starts to blink fast but will do nothing after that
This is almost always due to the guitar signal not getting to the TRIO guitar input. The fast blinking LED should go solid red on the first strum. Make sure your guitar volume is turned up and that if you have a volume pedal or tuner or any other effect between the TRIO and the guitar, that it is passing the signal.
Aug 22, 2015 | Music
I tried to plug in a digitech bp200 pedal and then my amp went on the fritz and starterd buzzing loudly. I attempted using the effects loop section on the back of the amp with my bass direct into the amp,...
DO NOT try a guitar pedal as an effects insert via the back jacks... they are for an external line level EQ/Effects type unit. Your guitar pedal should NOT have caused any damage. Check the power adapter you are using with the BP200. The BP200 takes a 9 VAC adapter, NOT a 9VDC type common to most pedals. You cannot use one of the Pedal Train type supplies with the BP200. Also check that you have the in's and out's correct on the pedal... backwards and they will cause what you are observing.. Verify your cables are good. The output of the pedal goes in the FRONT jacks of the amp. ONLY line level drives go to the back jacks.
Jun 05, 2011 | Hartke Lh1000 Bass Amp Head 1100 Watts...
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I need instrution manual for a digitec rp100a guitar effect
The manual you are looking for can be found right here:
ftp://ftp.digitech.com/pub/PDFs/Manuals/RP100A%20Manual%2018-1867V-A.pdf
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 22, 2010 | DIGITECH Guitar Effects Model No Ddm
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Digitech RP90 Expression Pedal
Same thing happened to me but i didn't drop the pedal.Try to recalibrate the pedal cause mine worked after that.Look in the Owner's Manual at the recalibration section.Hope this will work for you.Good luck with it!
Mar 29, 2009 | Music
DIGITECH VOCALIST LIVE 2 Logo
1,071 people viewed this question
Top DIGITECH Music Experts
Michial Gueffroy
steve cannon
Level 1 Expert
NOEL
NOEL
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
