Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Coffee leaks from the bottom of the coffee maker
  • 4 more comments
  • Anonymous Nov 04, 2007
    My Mr. Coffee pot has the timer that you set the time you want your coffee and instead of waking up to fresh brewed coffee, we wake up to a counter covered with brown water and a coffee pot 1/2 full. Any suggestions? This happens on a 6 cup pot as well as a full 12 cup pot.
  • Anonymous Nov 27, 2008
    The coffee is trickling back to the inside of the machine instead of running into the pot. It does this on the strong brew setting because of the slower process. Mr. Coffee needs to design the spout device with a steeper angle to guide the coffee into the pot so that it won't trickle back on the bottom of the spout. Also, tilting the entire maker slightly forward will remedy this problem, but to me this is an inappropriate fix. Mr. Coffee should have a better solution.
    Ugggg so glad that I am not the only person to have this problem
  • Anonymous Dec 15, 2008
    I have the same problem. The coffee drips back to the out side of the pot and down to the burner. It seems the flow of water is not strong enough.
  • mrlund921 Feb 17, 2009
    Put water in to make coffee and it runs out the bottom. Coffee maker is only 2 months old. It was in a box that was worn so I have the feeling it was returned to Target for the same thing it is doing to me.
  • ashlik321 May 23, 2009
    The water just runs out of the bottom of the FTX 43-2 model.  I am absolutely stunned because I have never EVER had a problem with a Mr. Coffee coffee maker in the past... NEVER!!! What do I do??
I just fixed my Mr. Coffee machine by removing the the 4 phillips screws in the bottom and re-attaching the red rubber hose to port it came off of. This is upsetting because if I knew this 2 months earlier - I would not replaced my old one with this one. These machines need a hose clamp to prevent this frequent failure. I will have some coffee now.
Posted on Jun 06, 2010
  • d15831 Dec 24, 2010
    Woke up XMas Eve am..to find the same problem.. Just had to remove four phillips head screws, pop out the two gray pads that hide two more STAR headed screws and remove them... To find one loose RED hose.... I pushed it back on , replaced the screws and ALL is well..... I probably will go to the store and get two small hose clamps and fix it right down the road.....
  • labouton Feb 23, 2011
    Another thing that happens is that the red rubber hoses tend to split causing water leakage out of the bottom. Unfortunately I haven't been able to find replacement hoses.
    Genius:
  • 1,554 Answers
Remove the inner basket that holds the coffee filter and look at the bottom. is the spring and plastic lever intact, the lever redirects the coffee from the bottom port over to the pot. if it is missing or damaged then the coffee will dump all over the place.
Posted on Jan 26, 2008
I wanted to thank you you all for posting this fix up. My Mr. Coffee just did this today so I took off the bottom and sure enough the red hose was disconnected.
Thanks again!
Posted on Dec 08, 2011
  • 4 Answers
SOURCE: Unit leaks out of the bottom
Mine just developed the same problem. Me being an engineer, I decided to take it apart and found the problem. There is an aluminum tube shaped like a "C" with a heating element inside of it. Water flows through this metal tube, is heated, and then pushed via steam pressure. There is a metal brace that holds this "C" piece securely to the bottom of the machine. This brace is sharp and overtightened, which caused a small hole to form in the metal, causing the leak (in my machine of course). I am currently researching how to patch aluminum so I can hopefully fix it.
Posted on Jan 06, 2008
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
Posted on Aug 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
  • 236 Answers
SOURCE: Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Posted on Nov 21, 2009
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
Nov 21, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Water leaks
unds like there is a leak in the tank. Take it back for a refund/exchange.
Jun 12, 2009 | Black & Decker TCM700 Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Water leak
just had the same problem the heater ring at the bottom has a whole in it or the hoses have got a crack in it. use a no 9 torx driver to take the bottom off. the check hold it up get water in it and look for the leak. the heat ring should have white corrosion on it, that should be were the leak is
Jun 24, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Steam leak in GB Mia Espresso Coffee maker
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Jan 02, 2008 | Guido Bergna Mia Coffee Maker
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
3,184 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Jim London
Jim London
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
