Question about Jl Audio 500/1 Car Audio Amplifier
Need resistors for JL 500/1
Ive been lookin for resistors for my JL 500/1,does anyone know the ohms and even the colors for the resistors??
  • playap86 May 26, 2009
    thanks alot
    President:
  • Jl Audio Master
  • 1,114 Answers
If you have the old ones that you are trying to replace, Radio shack has tons, as well as guides to show you how the bands are deciphered. Hope this helps
Posted on May 25, 2009
JL Audio 250/1 blown power trans blown resistors possibly shorted transformer How do I test
You should get the schematic for it. I can tell if your reference to trans is for transistor or transformer. If you mean transistor, in that power circuit they are most likely http://www.mouser.com/ProductDetail/Vishay-Siliconix/IRFZ44PBF/?qs=sGAEpiMZZMvARmQSk64rFx%252biHG2Aqv9T. See if you can see any references to the parts on the board. One of the others that fails often is: http://www.mouser.com/Search/ProductDetail.aspx?qs=4kLU8WoGk0vGgdnitUP0Eg%3d%3d and
http://www.mouser.com/Search/ProductDetail.aspx?qs=4kLU8WoGk0vWou9qAZ%252bg5w%3d%3d
Jan 06, 2014 | Jl Audio 500/1 Car Audio Amplifier
I have a jl 1000/1 mono amp and my low ohm light was on and making a buzzing sound and found that there was a resistor that one of the terminals broke off and now no matter where i look i cant find the...
The 5 ohm could be challenging, what you could try is to get 2 10ohm 3 watt and put them in parallel. Will be 5 ohm and 10ohm is easy to get
Hope that helps
Jul 26, 2009 | Car Audio & Video
JL 500/1 Problem
You need the old transistor. Knowing it's brown is not enough; you need to know its resistance value. It sounds like the resistor you replaced with has too low a resistance value, causing the "cuts" in sound. Find the old resistor and then use this site to find out what you need:
http://www.dannyg.com/examples/res2/resistor.htm
Jan 13, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL audio 500/1 produces barely any sound
have you checked the input sensor on the amp?
Oct 28, 2008 | Jl Audio 500/1 Car Audio Amplifier
500/1 sub amp stopped working, burnt rubber smell
It sounds like the power supply failed. Generally when the supply fails in that amp, you have to replace all 8 of the power supply FETs and all 8 of the 47 ohm surface mount resistors. Many times, the supply fails because one or two of the output transistors have failed.
If you want to have JL repair it, you MUST go through an authorized JL dealer.
If you have a good local repair shop, they should be able to repair it.
Let me know if you have any other questions.
Aug 06, 2008 | Jl Audio 500/1 Car Audio Amplifier
Low ohm light on my jl 500/1
If the low impedance light is on, the amp probably has shorted output transistors. If you don't know of a good local repair shop, call 'several' of the local audio sales/installation shops to see who they use. If more than one audio shop recommends the same repair shop, they probably do good work.
May 08, 2008 | Jl Audio 500/1 Car Audio Amplifier
Input sensitivity
Make sure your multimeter is set for AC voltage.
Feb 20, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Low ohm light wont go off
It's likely that the output transistors failed in the amplifier and it will need to be repaired.
Nov 08, 2007 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
306 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
