Question about Maytag Washing Machines
Front loading Maytag Neptune doesnt drain all water
I bought a used maytag neptune front loader. The first cycle I ran with a washer cleaning product (no clothes) but the washer wont drain all the way out. Alot of debris was flushed out. I am not sure if the pump is clogged or if it could be something else. What can I try before calling a repair man? I just received a used Maytag Neptune from my husbands uncle and the first time my husband installed the washer it leaked and flooded the basement.  The drum will not spin at all and there is water in the machine but I can't see it.  The water will come in and water will go out but still there is water in the machine.  I have searched the web but thought I'd try asking here.  Any ideas?
  • Maytag Master
  • 3,361 Answers
Remove the pump and clean it out. Access the pump from the rear.
Posted on May 25, 2009
2 Suggested Answers
SOURCE: front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Posted on Mar 09, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag centennial top loader i left the lid open to soak some clothes and it drained on its own and now it is stuck in draining mode
Turn the machine off. Wait 2minutes close lid and start new cycle.
check to see if your drain hose is lower than the bowl....this will also cause the water to drain out
Jan 25, 2014 | Maytag Neptune MAH5500B Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Washer wont go through the cycles... it stops working before the final rinse cycle
    MAH5500B Maytag Neptune washer stops and I have to put back into star and not just wash one side wet clothes and Susie sige water drains can only hear a buzz and it takes many items and each shaved marked "nf" and "Lf"
    May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
    I have Maytag Neptune front loader washer. When
    Hi.
    Error LR means Locked Rotor.
    Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
    Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
    Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Neptune MAH 4000AWW works good but some whater is left
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
    You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
    You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
    Apr 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
    Won't spin or drain, have tried to rerun cycle and checked drain hose
    Check pump / outlet filter , refer to instruction book , clean and replace then re- try
    Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Won't drain all the way and door lock won't light up
    Clean out the drain pump and check the pump motor while it is dis-assembled.
    Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    242 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
