Question about Vacuums
How to change belt on my own
I need to know what to dissassemble to replace the belt.
  • 6 more comments
  • Anonymous Dec 09, 2007
    I need do how how to put on the brush belt
  • aunteenay Dec 18, 2007
    how to replace a belt
  • teshua2 Dec 21, 2007
    where' a link i can go and get the manual online. I just need to know how to take off the housing to get to the pully and brush roll. I've had other machines that were much more straight-forward without needing the manual. I've lost the manual in a move last year and have tried to figure this one out.
  • Anonymous Dec 31, 2007
    REMOVED SIDE COVER ---BOUGHT BELT----HOW DO I LOOP BELT
    AROUND THE SPOOL AND THE WHEEL ?
  • dennymac Jan 29, 2008
    Belt slipped off my Kirby. How do im put it back on?
  • Anonymous Mar 13, 2008
    how to change the belt.
  • Anonymous Mar 19, 2008
    Took off the housing on the bottom. The belt is wrapped around the roller, the roller cannot be accessed. now what>
    There are 4 MORE SCREWS, but one is under the engine, so not accessible. The brush is STUCK with hair and needs to be cleaned. That caused the Belt to break...
  • johnnynails Aug 29, 2008
    belt broke in my g4 kirby sweeper. how do i put the belt on?
  • 72 Answers
That depends on what kind of vacuum you have, please provide detailed information.
Posted on Oct 20, 2007
  • michael masterson Oct 27, 2007
    my bad, I saw the type later, this is how you replace the vacuum belt.
    1) disconnect the cord from the electrical outlet.
    2) remove the four screws at the corners of the brush opening on the bottom plate.
    3) replace with belt number 38528035
    4) slide belt over motor shaft, then slide belt over large pulley while rolling pulley towards front of vacuum.
    replace the cover and screws.
    the small belt isn't normally replaced.
    download a manual here:http://www.hoover.com/pdfs/manuals/U6439...
If it has direct drive it doesn't have a belt per se--check the manual--I couldn't find mine and relied on experience from older vacuums when it was fairly easy to change those sucker!
Posted on Nov 27, 2007
Parts manual
VacPartsWhareHouse.com has the most helpful parts manual and schematics for your model vacuum:
Electrolux EL7020A
Mar 15, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Motor making strange noise. How do you take apart a dirt devil featherlite bagged vacuum cleaner down to the motor. I can't get the red cover off the vacuum.
With most vacuums it's not necessary to completely dissassemble to the motor. Most rattles are either something stuck/jammed in, around the wheels and intake area. The rattle, if it's a knocking can also be the internal broken rod of the roller. Rollers can be purchased at hardware stores. Even Walmart and Target carry many models. There are screws in the back and front and guide tabs that the housing cover slips into in the front to remove the top cover as a last resort.
Try cleaning maintence 1st.
1) Unplug
2) Flip over and remove screws on the belt and roller face. Remove face-expose belt &brushes.
3) Slide brush out of grooves. If the belt makes you nervous, slide a large screw driver through it's loop to hold in place while you clean the roller.
4) See if the belt is in good condition free of cracks or tears. If it needs replacing, it slips over the motor spindle for simple change outs. The belt and roller part number should be listed on the vacuum if you look atround. Usually on a metallic plate installed during manufacturing.
You can take a 4' length of old garden hose and listen through it to the outside of the motor while running to see for sure if the noise IS coming from the motor, or infact it's the roller. I hope this helps you.
Sep 22, 2011 | Vacuums
My older Dyson DC14 (the purple one) early model with a clutch on the beater bar belt needs a clutch replacement. The bar has been cleaned and there are no worn or damaged parts so I conclude that the...
Have a look at www.dysonmedic.com which has some very useful info on dismantling and repairing Dysons.
Although this site doesnt actually cover the DC14 yet, the DC14 is very similar to the DC07 so as regards dissassembling the machine, and replacing the clutch, my experience is that the DC07 info will enable you to do the job.
Mar 26, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Water does not come out of the bottom like it used to. It comes out of the accessory hose. I don't know how to change belts, etc.
You need to replace the belts. Here is a link to the belts you need, they come with printed step by step instructions.
Bissell 1699 Belts
Feb 10, 2010 | Bissell 1699 ProHeat Clear View Upright...
Replace power cord on Dyson DC07
The following link will take you to an article on how to change the motor on a DC07. Look at photos 4, 5 and 6 which shows how to disconnect the power cord.
http://www.dysonmedic.com/DC07%20Folder/DC07%20Motor%20change.html
Reassemble by reversing dissassembly instructions.
Dec 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brush is not rotating on Dyson vacuum
That is an indication that you need to change the belt. Do you know your model? You can find all Dyson replacement belts here:
Dyson Replacement Belts
Dec 20, 2009 | Vacuums
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
The brush on the vac. does it spin on it own or only when the vac is in position
You probably need a new belt. You didn't specify your brand or model but you can get replacement belts here:
Replacement Vacuum Belts
If you can let me know the Model number I can direct you to the exact belt and give you instructions on how to change it.
Oct 29, 2009 | Vacuums
How do I replace the belt on my eurika vacuum it is a boss model.
Did you say that you have a Eureka? Also you need to know the model number because belt changing methods and belt sizes vary depending on the model. You can find the model number on the vacuum and can find the belt you need in the manual. Then you can get any Eureka belt here:
http://vacbelts.com/index.htm
Oct 28, 2009 | Emerson Vacuums
I need to replace the belt on my vaccum. I lost my manual.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698951
Generic problem for all Vacuums
Posted by 4eversofia on Jun 23, 2008
I need to replace the belt on my vacuum. I lost my manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top.The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Vacuums Logo
1,831 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
