Question about Pioneer VSX-D557
Rca preout not putting out anything after amp/subs are hooked up and ready to pound
Rca preouts not working on my pioneer deh-1600 amp and subs are hooked up and grounded, and thump hard in any other car, but not with this HU, what's going on?
  • rickjamz19 May 25, 2009
    not on my deh-1600, i have been through every menu and can't find a single sub out or even rca aout selection on it, wondering if it is constant and the preamp out rca was fried by the previous owner
    Scholar:
  • 96 Answers
On most Pioneer's, there is an option in the main menu that allows you to turn the sub-out on or off. This must be on to let a signal pass from the head unit to the amp. Check this, and if it is on, try replacing the RCA cables. Let me know if this helps :)
Posted on May 25, 2009
  • Richard Neely
    Richard Neely May 26, 2009
    ok, are the sub's doing anything at all? Also, does the green light on the amp come on? And Is the fade control set to the middle?
In audio settings the Preout setting won't stay locked in. It keeps defaulting to "rear speakers" so no signal is outputed through the RCA jacks to the amp/sub. Can anyone help? Thanks!
If you had it professionally installed have it looked at. If you done it your self then check the wiring and make sure the wires are done clrrectly. Check the ground
Jul 07, 2015 | Pioneer DEH-P5200HD Car CD Player - 200 W...
I just installed a kenwood dnx7140. Everything is
Have you checked to see if the sub amp is turning on. Check to make sure you have at least 12 volts on your power as well as your remote turn on (Blue/White on radio harness).
If everything is hooked up correctly, it is possible that the preout is turned off. Some headunits have selectable preouts. If so you should be able to turn the sub on and off in the menu.
Hope this helps
VOTE
Mar 08, 2010 | Kenwood DNX7140 Car GPS Receiver
2v preouts from deck want to make them higher voltage for amp
You can get a line driver, it will add the volts you need and they are adjustable, Audio Control has some nice stuff.
May 31, 2009 | Pioneer DEH-P760MP CD Player
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
May 16, 2009 | Kenwood Audio Players & Recorders
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Jan 22, 2008 | Audiovox BA100 Car Subwoofer
Onkyo 805 sub hook up problem
Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
Jan 05, 2008 | Audio Players & Recorders
239 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
