Question about Kenmore 73952 Gas Dryer
Kenmore dryer model 64602 wont turn on???
My dryer just stopped working. The light inside will turn on, but the dryer itself wont turn on at all. Any ideas??
Thanks
  • Kenmore Master
  • 3,361 Answers
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
Posted on May 25, 2009
Kenmore dryer model 110 60622990, runs great but blows cold air
This video will show you how to troubleshoot your no heat problem.
Aug 09, 2011 | Kenmore 64602 Electric Dryer
Kenmore model 66722691 stopped running. light comes on timer works but wont start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Kenmore Dryers
My kenmore gas dryer ,model number 87673800, wont start anymore. It worked fine and then during use it turned off and wont come back on at all. Even the light is out inside. Any help would be greatly...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 21, 2010 | Kenmore Dryers
Just found water inside of my dryer. This has never happened before. Is it condensation?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 13, 2010 | Kenmore 64602 Electric Dryer
My dryer wont work. my kenmore elite wont turn on. the light in the dryer is working so I know there is power to the unit but the control panel wont turn on. The model number is 110 60092991
Kenmore by Sears,
DD
This is really a simple project
I believe your belt broke and Kenmore put a kill switch to protect your motor and heating element.
there are two screws when you remove your lint screen.
Remove those screws.(philips)
With a straight screwdriver, gently pry up the top of dryer.
When loose, open all the way to the back and rest on the wall,
On each inside,behind the door, at the top, is a 1/4" bolt. Use Socket to Remove both. Pull up and out on the front and put it to the side.
Remove the drum.
Now you can clean the inside with a vacumn. See the kill switch in front of motor.
The model is inside the door on the left
since you have it apart check the drum rollers for flat spots as well as freedom in movement DO NOT GREASE
Put it back together
Jul 24, 2010 | Kenmore 63942 Dryer
How to change the belt in the kenmore dryer model number 110.62822101. Dryer is not spinning so I would assume its the belt correct?
It is indeed a belt issue if the dryer blows hot air, which means the motor is running, but the drum does not turn. Otherwise, the thermal fuse (part number 3392519) mounted on the blower has failed. This thermal fuse is wired in series with the motor circuit and its failure results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
May 29, 2010 | Kenmore 64602 Electric Dryer
Dryer has no power
Have you manually reset your breaker? Sometimes breakers can seem fine but they actually aren't. Physically turn the breaker off and then back on. If this doesn't work, you will need to find out if your particular brand and model has a fuse that needs to be replaced.
Apr 08, 2009 | Kenmore 64602 Electric Dryer
Kenmore Dryer 80 series will not turn on.
HI thanks for your question. theres a belt break switch on the dryer so that if the belt breaks it wont allow the dryer to start. check that. thanks the appliance doc. please rate my answer .thanks
Oct 05, 2008 | Kenmore 62602 Electric Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Condensation inside empty clothes dryer
yes,also if you have a front load washer you do the same thing,hope this helps-mike
Jun 16, 2008 | Kenmore 64602 Electric Dryer
Kenmore 73952 Gas Dryer Logo
182 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
