Question about Precor EFX 556 Elliptical
No power, when I turn the switch on, the power lights do not display
I have had the Precor for 8 years with no problems and we used it and the next day, the power switch does not turn the power on. No lights are displayed in any mode. I have tried different outlets and I know their is power to the outlet it is plugged into.
    Problem Solver:
  • 15 Answers
Look on the back for a reset button, it could be a small red button the size of pencil lead protruding slightly, push in on it. It could also be located in side a small hole the same size use a tooth pick or something none metallic to push with...
Posted on Jan 09, 2014
SOURCE:
Precor gfx 9.33i displays "stuck key"
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
Apr 20, 2014 | Precor Deck, Treadmill, OEM
Precor error 3
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Feb 22, 2014 | Precor Exercise & Fitness
Removing a user I'd password from a precor 935 2005
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Dec 21, 2013 | Precor 935 Premium Series Treadmill
Precor treadmill code e3 is on
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Precor error code 1
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
How to unlock safety code for precor 9.35 treadmill
• Set User Name
Procedure
Sep 27, 2012 | Precor 9.35 Premium Series Treadmill
What is the password the get the precor 3.1 treadmill to work?
• Set User Name
Procedure
Jan 27, 2012 | Precor 9.31 Treadmill
My Precor 9.31 does not respond to the down arrow on the left hand side of the panel. The PW? requires the left down arrow, and the right two arrows to be pressed consecutively. Unfortunately, the left...
1) Clean the contacts, with contact cleaner spray( radio schack or computer store) if you remove the cover will be better for to do it. With carefully and disconnect the power cord for to avoid danger to you and the equipment.
2) If you can adjuts after that sensor reed switch to 1/8" see the diagram attached, will be good, and will be
good idea if you replace the sensor reed switch or optical disk.
3) After that you can conclude if the problem persist after adjustment or replace the sensor the trouble will be the display console faulty, Do not conect anything after you are right with your problem..11_18_2011_4_58_22_pm.gif
Nov 18, 2011 | Precor 9.31 Treadmill
`STUCK KEY` shows when machine is switched on and will not work
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console.
Try to tight the flexible cable from Keypanel vs Display board and then tigh the connector from display board vs lower board or main motor controller.
Clean the keypanel with contact cleaner spray(radio schack or computer store):
adjust according with diagram attached 1/8" aprox +see the block diagram how the main motor board has aprox 90% of functions of any treadmills. Now you will have powerful resultant what is wrong.
sincerely Good luck, and God bless you.
E.CUADRA
MANAGUA, NICARAGUA.
Sep 23, 2011 | Precor C956i Treadmills with HR /...
Precor EFX 556 Elliptical Logo
310 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
