Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
We have a 1/2 HP craftsman garage door opener that will not close
It won't close unless we hold down the button but will open with one hit of the button. led is bright even when other sensor is blocked. remote will not close at all even when holding down but will open door. we did have power outage day before
  • 1 more comment
  • djones1249 May 25, 2009
    DOOR WILL NOT CLOSE UNLESS YOU HOLD BUTTON ON WALL DOWN. REMOTES WILL NOT WORK.
  • koala626 May 26, 2009
    thanks for the suggestion. any idea how that happens?? i will tell my husband! have a great day!!
  • koala626 May 27, 2009
    so makes sense thank you so much!
    President:
  • 3,197 Answers
You have a bad logic board. Cost is about $80.00 for the part.
Posted on May 26, 2009
  • Don Maggard May 27, 2009
    It is common to have an electrical surge along with an outage. This can cause the type problem you are having.
Garage door will not close unless you hold inside button down
It could mean that there is something in the way of the electric eye or that they are misaligned. They are about 18" up on either side of the garage door. Check for interference or they may have been bumped and need alignment
Oct 15, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Craftsman Door Opener Model #139 53975SRT1 1/2 HP will not open the garage door. It will close it. And if it's on the way down and I hit enter, it will open mid stream. But, if it's closed, an
Two things. Check for a broken door spring. If okay, remove the cover from the motor housing and check for a bad drive gear. This is a white nylon gear just in front of the motor. If it is going bad it should be obvious.
Jul 05, 2012 | Sears Craftsman LiftMaster Chamberlain...
41a4315-7d remote opens garage door, but it won't close it; in order to close the door i have to use the wall mounted button and hold it down until the door closes all the way to the concrete. if i...
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Aug 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman garage door opener opens fine. It
It could be closing too far or the sensitivity could be set too sensitive.
Lube the springs, wd-40 rust may be the whole problem.
If the door hits and the opener continues to move until the rail flexes upward and then reverses - probably the travel adjustment.
Does the door close and stay closed if you hold the wall button down constant until it closes? - this would indicate a safety eye problem.
If the door reverses before it hits the floor or just as it hits the floor it could be the sensitivity or if the safety eyes are mounted to the track they could be flexing enough to move the eyes out of alignment.
Hope this helps.
Jul 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door won't close unless I hold the main button down in the garage. As soon as it closes it opens up again unless I press the button quickly. I can open it up using the remote, but cannot close it...
your garage door has saftey sensors at the door
these are photo eyes
in the owners manuel that came with the opener
that has pictures in it which would help
the photo eyes need to be clear of debri and aimed at each other with no obstruction
there are leds on each sensor and when aimes properly they should be light if i remember correctly
if you can not get them to light then you may have to replace the sensors
Oct 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Myt 1/2 hp craftsmand door opener clicks and light
If the main light flashes 10 times when the door reverses it is a door sensor problem. Each sensor has a small light that needs to be lit and not flickering for them to work. They must be pointed at one another for the lights to be on. Tweak them a bit and see if the lights come on. If not you likely have a bad sensor.
Oct 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Oct 07, 2009 | liftmaster Chamberlain Garage Door Opener...
Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
363 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
