Question about Frigidaire FAC124 wall/Window Air Conditioner
Frigidaire thru-wall AC drips water when AC is on
When i have to AC on after a little while it leaks water, I have to have a trashcan underneath of the AC inorder to catch the water. I tried turning up the temp. to see if it is was stoo cold. When my dad and I took it a part a little there was A LOT of water that we tried to clean up.. how can i fix it? or do I need a professional?
It was even tilted so we tried to untilt it to help it work and that did not work either.
Thanks you!
  • Frigidaire Master
  • 3,361 Answers
The drain line is clogged.You will have to remove it again,open it up and access the drain line and clean it out.
It will be on the right or left corner of the evaporator coil(inside coil).
You will probably have to take it outside and use a garden hose the spray water into the drain until it runs freely.
When you reinstall it tilt it 1/2 inch to the rear.
Posted on May 25, 2009
Leaking drain tube ac
Is it leaking inside your car? This means that your exit drain pipe is blocked. They are in the engine bay usually near the fire wall and they are commonly a thin rubber hose that drips that water onto the ground. look up underneath and use an air compressor to blow it out or a screw driver to clean it out.
Jun 27, 2013 | 2007 Toyota Avanza 1.3
It sounds like their is water in the blades and its not cooling my room
Tip the AC slightly downward on the outside so that the water can drip outside. If should be a hole for the water to drip away, make sure it's not blocked. Close your windows and doors. As long as cool air is coming out of the AC, it's working.
Jul 27, 2011 | Haier HWF05XC7 Thru-Wall/Window Air...
What is the location of weep holes in a 1999 Aurora Olsmobile. They seem to be clogged and are causing the interior of the car on the passenger side to drain water inside. I've seen water drip along the...
9 times out of 10, thats from a leak in the heater core. Thats the little radiator type thing that the air blows thru to heat your car. It runs antifreeze thru it. Its connected to the coolant system and heats up with your car. Normally can see the two pipes running thru you the wall from under the hood to the inside bhind dash. It can be located on the passenger side or the middle console. Can you see that little green arrow?tayjoejoe_1.jpg
Apr 12, 2011 | Oldsmobile Aurora Cars & Trucks
I have water collecting on the bottome of my side by side refrigerator on the frigerator sided un the crisper.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Sep 17, 2010 | Frigidaire FRS6R5EMB Side by Side...
Water keeps forming in refig
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator compartment. This is all you need to do....
Best of Luck,
Concerned.
Aug 11, 2010 | Frigidaire Refrigerators
Water leaking inward
There should be a drip tray that catches all the condensation and funnels it out the back. Check for holes, cracks or a plugged drain hole.
Aug 30, 2017 | Frigidaire FAC124 wall/Window Air...
Leaking water from underneath.
Hello my name is Heath it will be my pleasure to assist you. The drain should be in the back of the unit outside . If you lean the air conditoner slightly toward the outside it should drain outside.
Jun 28, 2010 | Frigidaire FAA084P7 Thru-Wall/Window Air...
A lot of water leaking out of A. C. into neighbor's window below
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Aug 17, 2009 | Frigidaire FAC126P1 wall/window Air...
Frigidare thru-wall AC drips water when unit is on.
Do not try to drill any holes but search for the built in drain and open it. Again do not use a drill. Get a shop vac.
Jun 09, 2009 | Frigidaire FAC124 wall/Window Air...
Frigidaire FAC124 wall/Window Air Conditioner Logo
364 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
