Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation).
Press and hold the Power button for seven seconds until the Power dialogue box appears, and then tap Restart.
Note: If the Power dialogue box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
When was the last time the tablet was turned off (not just put into sleep mode)?
To turn off the tablet, hold the power button for two or three seconds, then tap "shut down" when asked if you want to shut down your Kindle.
After the device has completely turned off, press the power button to restart.
Please reply with more information if this did not fix your problem!
Seems like the digitizer isn't working anymore u may wanna get ur tablet examined but to quickly turn off some tablets is to press and hold the power key till it shuts off and not lock the screen
There usually is a reset pinhole where a straightened paper clip can be inserted to press an internal switch. this hole is usually on the edge. press and hold the switch for up to 10 seconds lightly. then the ereader should restart
Here is how you fix this problem: Hold both the power button AND the volume UP button down at the same time for about 5-10 seconds it should restart. You don't lose any info doing this.
Update your firmware by using your sd card... place sd card in compurter...Go to galaxy website download firmware to your sd card then follow direction from website how to start the download on your galaxy.Good luck
