Question about Dryers
Kenmore gas dryer
Where is the pilot light on an older model kenmore gas dryer  model # 77974110
  • 1 more comment
  • samantha67 Oct 22, 2007
    Thanks We figured that out after a couples of hours and connecting the gas.
    Thanks for your help.
  • Anonymous Mar 31, 2014
    the pilot on the dryer will not light
    how to light pilot light on dryer
I have a kemore gas dryer model11097282100 about a1993
and it no longer will heat. the drum goes but does not heat.I can,t even figure out how to take off the front if any replacement is needed
Please help,deb
Posted on May 06, 2008
  • 94 Answers
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Posted on Oct 21, 2007
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
I need to know where I light the pilot of a Sears Kenmore Dryer Model number 8737400 please
There is no pilot light. Even the gas models power up by electricity. Sounds like one of your thermal cutoffs is bad or your element!
Aug 21, 2010 | Kenmore Dryers
Kenmore model #77974110 gas dryer won't heat
with that brief description, i can only suggest a few primary and common problems. check the door switch. the igniter is not igniting due to breakage or a loss of signal. or, the gas solenoids are burned out. listen for the sound of buzzing; if you hear a buzzing and get no ignition, the solenoids are probably shot. if you can look into the unit near the bottom, turn it on and see if you see a glow. if you do the igniter is probably good.
there is on most models an igniter sensor; that might be an issue
thats all i got....hope it helps...........................jay
Dec 04, 2009 | Kenmore Dryers
My dad has a kenmore dryer and cant get the pilot to light.how do i identify what model it is?
kenmore usually put there model plates under the lid on one of the lips,,,,
you can look on the back of the control panal as well
Nov 02, 2009 | Kenmore 84052 Dryer
Gas Dryer model 110-77974110
the coils on your gas valve are going out , this is why it will work at first and stop , the coils heat up and wont open the valve again after they are heated.
I thought they were some what cheaper than they are now but still not too bad. you can try this part number search on ebay for the best price I can find.
279137 coil kit
Phil
Jun 11, 2009 | Kenmore 74602 Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Dryers Logo
559 people viewed this question
Top Dryers Experts
Marvin
Marvin
