Question about FrancisFrancis! X5 Espresso Machine
Heating element burn out
Apparently, the heating element on our FrancisFrancis burned out because the temperature does not rise.
Picture showing burnt out heater element and top removed from X5
Most problems with too much heat, too little or circuit breaker tripping most likely point to this.
If your water is "hard" then this will happen. Clean with vinegar weekly, or one of those expensive solutions they sell to avoid this.
Part ordered through illy's parts sub, $35 and 3 weeks. About 2 hours to disassemble/reassemble.
Posted on May 30, 2009
  • justin_steig Sep 24, 2011
    Do you have a link or store where I can get this Part?
    Scholar:
  • 36 Answers
If you are getting power but no heat then it may be the element or there is a small thermostat on top of the boiler which could have blown or it may be a faulty wire. If no power then it may also be the power cable. I can get parts that you require but you would be best to use a multimeter to test all the bits to see what it is you actually need.
All the best
LaPavoniBoy
Posted on May 28, 2009
Replacement element I used on my x5. The boiler is the same one in the Le'lit:
http://www.1st-line.net/cgi-bin/category.cgi?category=review&item=MC029-110&type=store
Posted on Jul 26, 2010
  • flemster Oct 06, 2010
    The MC029 heating element from 1st-Line Equipment works fine on the X5. Don't forget to order two small silicone o-rings (MC045, 9.25 x 1.78) and one large silicone o-ring (MC046, 71.12 x 2.62). These aren't included in the price of the new element, but you'll probably need them if your boiler is old enough for the element to have burned out. As of Sep 2010, the element, o-rings, and shipping was about $55.
  • vlad359 Mar 15, 2011
    Do you have any idea if it'll also fit the X1?
    Thx!
Oven is over heating to set temp
Well if that is really happening you would need to make sure that the temperature gauge is working properly
Jul 31, 2016 | Frigidaire Gallery 30" Self-Cleaning...
The bottom oven is heating up very slow.
If you are having problems with your electric oven heating up too slowly, not being able to maintain temperature set point, or wild variations in temperature, then you probably have a bad baking element in your oven.
The bake element is the bottom element in your oven. The life span of these elements can vary depending on the usage of your oven and the quality of the element. Anything electric has an unpredictable lifespan. Elements made on the same assembly line can vary greatly in how long they last. But when the element burns out it will need to be replaced to have your oven work properly.
The thing the fools many people is that many ovens will use the broil element to preheat the oven and then switch to using the baking element only. When this happens the oven will no longer heat and will cool down. The unit may sense this and activate the broil element again which will cause wild swings in temperature and also can cause food to burn on the top self or not bake properly.
If you can see the elements, watch them and see if they both get red hot when initially warming the oven. If only the top, broil element gets hot then you have a burned out element or a bad contacts where the element plugs into. Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good.Bad elements will often have blisters, bubbles, or even burn in two.
If the element contacts are bad, make sure the you replace both the element and the receptacle that the element plugs into. Replacing only the element will only temporarily solve your problem.
Jan 23, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Turned on the machine today and nada, nothing...no light, pump or any sign of electrical activity. First time in a yearn and half. I checked the outlet and it's fine... Wondering if there is a fuse or any...
Your heating element has probably burned out. You will need to find somebody who is familiar with an electrical meter, take the top of the machine off and check voltage between the two electrodes going into the boiler. If there is voltage but the boiler is cold, your element is burned out. We can fix it. www.dolcevitaespresso.com
Jan 20, 2011 | FrancisFrancis! X5 Espresso Machine
Hi, I have an X1 francis espresso machine. I am having a problem with the machine heating up the water. I am not sure if it is the element, or the thermostat. The temperature guage does not rise above...
The thermostat is a bit that goes into a hole on the boiler, connected by a wire to the gauge. It is most likely that the thermostat has come unstuck from the boiler and is registering incorrectly.
Sep 06, 2010 | FrancisFrancis! X1 Espresso Machine
Heating is not hot
Either the wires to the heating element have burned out, the heating element is shot, or the temperature sensor is shot. Unplug the dryer and check the heating element for continuity, check for burned wires between the relay and the coils, and check for continuity across the cold temperature sensor. Replace any defective parts.
Dec 01, 2009 | Frigidaire GLER341A Electric Dryer
Burned out lower element, replaced now have uncontrolled heating, tempature rises very fast and can not be controlled
You have burned out the temperature probe or the temperature knob to see where it is located and how to remove go to http://www.appliancepartspros.com and type in your model number and yo can find it there and how to remove it. If yo have an ohm meter you can test the pyrometer with the ohm meter. If the control knob has burned out you will get power on all the time. MY guess will be the pyrometer sensor is defective.
Nov 22, 2009 | Kitchen Ranges
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Burning smell
thermal switch is not working...upon reaching a certain temperature limit it should switch off then switch on again after a moment to maintain the set temperature..what happened here is that your thermal switch didn't switch off so the temperature continue to rise to the extent that the heating element burnt and smell like that..adjust the setting in such a way that it switches off after reaching the desired temperature..
Jun 18, 2009 | Rowenta Irons
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
FrancisFrancis! X5 Espresso Machine Logo
1,567 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
