When i turn the volume knob ether one channel crackles or both do. I can play with the volume knob, the source selector, or the balance slide it to get both channels working. But sometimes i cant get one of the channels working it will have a crackle to it till i play with every thing more. It does this on all sources.
First unplug it. Sounds like you need to spray some tuner cleaner in the pots that are crackling. Pull the knob off and you should be able to use a spray can of tuner cleaner with the straw that comes with them to spray into the potentiometer , then rotate the pot several times while it is still wet. After cleaning them all, wait 10 minutes and then try.
SOURCE: No output from left channel after crackling sound
does your unit have a volume knob or is it a paddle type with up and down?
SOURCE: Marantz SR-18EX; Front left channel crackles
The f-l channel of the sr18, & sr18ex & sr19 is a common failure location due to the heating and cooling over the years. The crackling an/or distortion, is most commonly due to the amplifier going into a high idle, or d.c. offset that can no longer be controlled by the adjustment potentiometers on the board. usually the two 2sc3200 transistors become unstable, and as well a 47mfd and a 470 mfd elect. caps nearby. Also distortion is caused by one or more of the zener and germanium diodes all grouped near the big dual ceramic white resistor. The amp block is held in by six screws. first remove the cross bracket, then cut the cable tie free from the hole on the board. Ten screws hold the top board on, the pull the boards apart from the connectors. before replacing it, resolder ALL of the connector pins to BOTH boards.
