Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Fuel line positions ?
I have a ryobi 700r 31cc grass trimmer.The fuel lines were cracked and leaking. I replaced them but mave have not put them back in the correct position.It will not start and the fuel keeps on running out of the carburater. Imay have the fuel lines in the wrong place. Could you tell me if the line closest to the carb. has the filter inside the tank and from there goes to the bottom of the carb. or does the line furthe back in tne tank go there or to the primer bulb. Please advise .Thank you. Norman. squirenph@yahoo.com
  • 1,041 Answers
The longest fuel line, which has the filter attached to it, goes to the brass fitting furthest from the primer bulb. The short fuel line goes directly under the primer bulb. Which hole to put it in doesn't matter if the lines are the same size. Just choose the shortest path for each. However, if the lines are different sizes, then the longest line (smallest in diameter), goes in the smallest hole of the tank.
Jim
Posted on May 26, 2009
  • Jim Parker
    Jim Parker May 27, 2009
    Thanks for the rating Norman. If you have any drywall finishing questions, or know someone who does, put your questions to "Tools-Building & Power-Hand Tools".
    Jim
What is the oil-fuel mixture ratio for the Ryobi 700r grass trimmer?
33:1 to 40:1 is typical on about 95% of all line trimmers. I own (2) 700r's and one is 32:1 and the other is 40:1, you won't go wrong at 35:1 with current 2-cycle oil. Suggest using low-smoke brands.
Aug 29, 2010 | Sport & Outdoor - Others
Ryobi 700r gas trimmer. Leaking fuel from the fuel return line...what is the best way to fix this?...seems to be leaking where the tube goes up into the fuel tank. thanks.
There is no nipple. The fuel line is just pushed through and holds itself tight against the hole in the tank.
This is the return line from the primer bulb, right?
Just replace the line and you should be fine. I think that some of these Ryobi lines are 3/16 OD and 3/32 ID, but I just picked up a Ryobi fuel line kit at Home Depot today, and the black line seems to fit nicely here. (My trimmer still won't start, but at least it doesn't leak gas any more.) Be careful to note which line comes from where on the orimer bulb.
Steve
May 12, 2010 | Garden
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
TRIMMER WONT STAY STARTED
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spraywith carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 21, 2009 | Ryobi Garden
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
641 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
