Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Pressing the menu button on the remote I go right into the osd VIDEO settings but how do I go from Video settings to CHANNEL settings
  • Westinghouse Master
  • 13,433 Answers
Hi
can you send me the brand and model and I'll look into it, is a Westinghouse, and whats the model? 22" wide flat panel lcd?
Posted on May 25, 2009
  • Ekse May 27, 2009
    Hey,
    I got your message about the model.
    Viewing OSD Menu
    To display the main menu, press the Menu button on the right side of front control keys of
    the LCD TV or the MENU key on the remote control. Press arrow keys to select desired
    OSD menu and Enter key to select desired setting.
    As on the above picture, the Left key should exit to the previous menu. So pressing Left a few times should get you out from the video settings and back to the previous one and then back into the selection If I understood this correctly.
    Also on the side of the tv you have the function keys, one of them will adjust the channels. But I think most of the options are only available in the menu.
    you can email me directly at nikoht@gmail.com to respond or use this link to write a reply
    http://www.fixya.com/PostComment.aspx?th...
Reprogram channels on my Westinghouse tv model sk26h520s for a new location
Make sure that the source is set to TV. If you use the original remote, press the top button between the volume up/down and channel up/down buttons. If you use the buttons on the side of the TV, the Source button is next to the Channel Down button.
Next press Menu. (On the TV, it's the top button. On the remote, it's the top left button next to the arrow keys.) Now navigate down to Channels (use the Channel down on the TV) and press Enter on the remote (or Menu on the TV). Navigate down to Scan Channels and press Enter or Menu (as needed). Choose Antenna or Cable, depending on your source and press Enter again. (Note: the volume buttons on the TV are your left and right arrows in the OSD.) If you get a confirmation notice, select Yes and press Enter.
I hope this helps.
Dec 31, 2014 | Westinghouse Televison & Video
Tip
How to get OSD on TV for a Pioneer Receiver
OSD for on your TV for a Pioneer Receiver setup menu. (It doesn’t matter what make your TV is).
Connect the MONITOR OUT video jack on the receiver to a video input on your TV. Use a standard RCA video cable to the composite video jack.
Turn your TV on and put your TV onto AV3. Turn your receiver on, then on your remote control push the receiver button (this is not the on/off button, there is another button with receiver written on it) then push the setup button on your remote control. You should get the OSD menu on your TV for the settings for your receiver.
on Jan 03, 2010 | Audio Players & Recorders
Unwanted channel display in middle of screen
TO REMOVE CHANNELSscreen13.gif 1. Press the MENU button on the remote control to open the OSD.
2. Press the Navigation (UP/DOWN) buttons to select the Setup menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to select MANUAL SEARCH.
5. Press OK to select.
6. Select the channel you want to delete from the channel list.
7. Press the Navigation (LEFT) toErase Channel.
8. Press EXIT to close the OSD.
Feb 29, 2008 | Televison & Video
How do i change language on samsung hmxu10bn i accidently changed to a forin language and i cantchange it back to english
You can change the OSD language (that the camcorder displays the menu screen/options and messages) by:
1. Press the MENU button - the menu screen appears 2. Press the < (left) or > (right) button to select "Settings" - the settings menu appears 3. Press the ^ (up) or v (down) button to select "Language" and then press the OK button 4. Press the ^ (up) or v (down) button to select the desired OSD language (English), and then press the OK button 5. When you're done, exit by pressing the MENU button and all the menu options & messages will be refreshed in the selected (English) language.
Feb 27, 2011 | Samsung Video Cameras
My tv is stuck in retail mode, how do i reset that?
Enter the OSD menu by pressing Menu on the remote or the TV. Press the down arrow to reach Installation (bottom of the list) and then press the right arrow to to enter this menu. Then navigate to Preferences (third in the list) and press the right arrow. Then navigate to Location and again use the right arrow to enter this item. Set the unit to Home instead of Shop. Press OK on the remote to save the setting. Then press Menu to exit the OSD.
If you are using the controls on the TV, use the Volume +/- buttons to navigate left or right in the menus. The Channel Up/Down buttons will let you navigate the vertical menus.
Once in the Home Location, you can adjust the color or brightness. From the Menu, choose TV settings and then Picture.
I hope this helps.
Dec 07, 2010 | Philips 50PFP5332D 50 in. Plasma...
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Olevia not searching channels
try the following..
Q. Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q. Why does my TV display "No Signal" or "Channel not in List"? A. Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
  1. Press Source button until Tuner is visible on the upper right corner,
  2. Press Menu button from the remote,
  3. Press Down arrow key until you see Setup, then press the Right arrow key,
  4. Press Down arrow key until you see TV, then press the Right arrow key,
  5. Press Down arrow key until you see Auto Channel Search, then press the Right arrow key,
  6. Press Down arrow key until you see Air (for antenna; select Cable if you have cable service), then press the Right arrow key. The scan process will start.
  7. Wait until the process is complete then you will be able to select the channel you like to watch.
Jul 29, 2009 | Televison & Video
OSD
If you have checked thru the owners manual and could not find anything helpful for getting the OSD working again, you may want to try this reset procedure at the end of this post and then try to get the OSD working again. The owners manual should give instructions on how to activate the OSD.
This reset procedure will clear all the setting you have made, so make sure you know how to put those settings back in again before doing this.
If you do see the video from what ever video device you have connected to the unit (DVD player ect. ) but you don't see the OSD when you enter into any setup menu, then this reset procedure may help fix that problem.
If you are not seeing any video from the video device connected to the unit, then you may just have the wrong setting for the output from the video out to the TV. These Denon's are very complicated receivers (which you must know, since you own this receiver), and an improper setting can be causing the problems you have.
Befor eyou do this, go thru the settings menu and look for a OSD setting and see if it is turned off. If so, turn it on. If you can not find anything for the OSD try using the set up on the display of the Denon instead of the remote.
Here is the reset procedure:
With the unit turned off, hold down these two buttons at the same time:
Pure direct + Direct
while holding those buttons down, then press the power button to turn on the unit. Keep holding those buttons down for at least 3 seconds after turing the unit on and the display should flash at about 1 second intervals. then you can let off the two buttons and the unit is reset back to the same settings as when it was new. You now will need to put all of your custom settings back in to the way you need them.
Jul 09, 2008 | Denon AVR-3805 Receiver
Setting up playstation
The PS50700 uses the PTK195 series chassis. You can switch the TV to the video mode by pressing MENU, press channel down 3 times to highlight "4 Channel", press MENU, press channel down twice to highlight "3 List and Labels", and then press MENU. The current channel will be highlighted, and you will press channel down until you go below channel 1, which is where the video inputs are (VID1, VID2, FRNT). To exit, press MENU, choose "Exit", press MENU and choose "Exit" again, or just wait until the menu times out. An easier way is to get a universal remote that has an "INPUT" button.
Sep 02, 2007 | Proscan PS50700 50" Rear Projection...
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
53 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Dudeman321
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
