Question about Garden
Removing the cap that encases the string... How?
How do I remove the cap that encases the string?
  • jscott_adams May 26, 2009
    It's a homelite S-40 trimmer. The spool for the string has a cap, with tabs. I can't figure out out to disengage it. I've tried pushing down and turning, with no luck.
  • becky swanson May 11, 2010
    what brand
  • 4 Answers
Try oppening it!!
Posted on May 29, 2009
How to remove the trimmer wheel to add more wire?
In order to add more wire, remove trimmer head by removing center main screw. The whole cap will come off with a little of force towards the outside. Then you will put the string inside the channels dedicated to do this.
Thanks
Jul 25, 2011 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Replacing the spool of string for my black and decker 12v electric trimer ? grasshog model
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
Jul 08, 2011 | Black & Decker String Trimmer Cordless 12"...
The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Starts up then shuts off and the primer button sucks in so its not getting gas. its not the vgas cap tried that already
You may try removing the fuel line from the carb, removing the gas cap and blowing air (low pressure or by mouth) through it to the gas tank. The in tank filter may be clogged.OR You can check by just seeing if fuel flows easily from the tank through the line.
Mar 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
How to remove the heater core and wre is it located
it is located in the middle under the dash and is quite accessable once you remove all the items in the front. this does not include removing evey single piece seperately. some items like the centre console can be removed by removing about 6 screws if i remember right.there will also be a black cover under there and the heater core is encased in there.
Nov 02, 2009 | 2001 Ford Windstar
How can I take out the side florescent bulbs encased in plastic?
Usually the plastic tube has two end caps that hold the plastic tube onto the lamp. These end caps allow the connection pins to go through a slot in the end of the cap.
If the lighting fitting is the turn type then turn the complete tube and over tube by the end caps and remove the tube/over tube. If it is in a lighting fitting where you just push the connection back and pull the pins out of the fitting.
The end caps will have a ridge that the plastic tube fitts into at each end.
I have seen some overtubes have screw on end caps.
Regards
Alan Hood
ami-man
UK
Aug 10, 2009 | Wurlitzer Jukebox 1015 One More Time...
Cant get the cap off to replace the string on a troy built trimme
The cap just pulls off but yes it will be tight if its the first time you have ever removed it to replace the nylon string. Use a small flat screwdriver to lever under the edge of the cap and pullng at the same time but be carefull not to break the plastic surround
Aug 02, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
GREEN BLINKING LIGHT
The caps that require replaceing are teh 1000ufd caps on the "DM" board. This board should be encased in a metal shield. Be careful when removing the board. Make sure that these caps are replaced with 105c caps not the 85c ones. (temp rating).
Dan
Sep 09, 2008 | Televison & Video
Capacitor locations
yes all wires need to be removed that run from the metal encased chassis the four boards that have bad caps are all located in that metal encased chassis. The FMT, DM, Singal and Power PCBs
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
