Question about Dell Inspiron E1505 Notebook
Computer will not start
I gave a Dell E1505 and I believe the motherboard is dead. When I plug the power adapter into on outlet the green indicator light comes on, however when I plug the other end into the notebook the green indicator goes out. The battery aoppears to be ok - all five LEDS light when I press the test butten. How expensive is the MOBO and how diffficult to replace.
  • Dell Master
  • 4,806 Answers
Hi there.
This is the starting price for a new motherboard >>>>>
http://www.smarter.com/motherboards/dell-inspiron-6400-inspiron-e1505-motherboard-/pd--ch-2--pi-1056066.html
To be honest with you they can cost just as much as new laptop and it's not easy to refit them either.
There is a lot that's involved with dismantling a laptop and can be more hassle than its worth unless you think you have the patience for it and have a good memory for where leads, screws and hardware goes.
The reason the LED on the PSU goes out is because there is a feed back problem either at the AC adapter on the motherboard or a powerboard problem, which to inspect or troubleshooting them requires disassembly.
Good luck and thanks for using FixYa!!
Posted on May 25, 2009
  • 256 Answers
In my opinion, if the motheroard is dead and it is an older laptop, it is now spare parts. BUT first, try another power adapter to make sure that is not the problem. You do not want to replace the motherboard with the same one, you should want to upgrade the MB. But laptops are one of a kind deals where a newer, better MB just won't fit. So after you have checked to make sure it is not something simple to fix, consider a newer laptop.
My Dell XPS 410 computer will not start, won't do anything.There is however an LED light on the Motherboard labled Stdby Led, this is lighted but the compter won't do anything? I am needing someones...
Your computer power button may not be working, or the CPU may be bad and it can also be the motherboard is faulty.You need a new case or fix the power button or try another CPU in the computer or replace the motherboard.
Aug 16, 2010 | Dell XPS 410 PC Desktop
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Power Problem. Sudden onset of laptop not coming
The most likely answer is the motherboard will need to be replaced. Here are some troubleshooting steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 14, 2010 | Dell Inspiron E1505 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron E1505 shorting out adapter
I would replace the battery if you had for some time. Over time charging a battery will slowly not take a charge. If you tried two adapters, about the only thing is left is the battery.
Aug 18, 2009 | Dell Computers & Internet
Dead e1505 laptop caused by defective PA-10 power adapter
go to your favorite search engine and put in your computer model number and put dell parts. It sounds like the motherboard, it is unlikely it could be the battery and or the adapter to go bad at the same time.
Aug 12, 2009 | Computers & Internet
Computer won't power on - completely dead!
Make sure you have power at the wall outlet then check to see if your power adapter is working properly. Most Dell's have a LED on the brick or on the cable that plugs into the computer that indicates power is applied. If the power adapter is working then remove the battery and see if it powers up. If it doesn't then your motherboard may need replaced.
Aug 05, 2009 | Dell Inspiron E1505 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
Dell inspiron b130
check if the ac adapter or charger has a green light on it. if not, replace the charger. for dell chargers, it should have a green light to indicate that the charger is getting power from the wall outlet. if the ac adapter is good, then you might need to replace the mother board as the ac port is integrated.
hope this resolves your problem.
Nov 12, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron E1505 Notebook Logo
236 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
