Question about HP DeskJet F380 All-In-One Printer
Why can't I select "black print cartridge only" in printing preferences/color tab on my HP Deskjet F380
    Scholar:
  • 57 Answers
If you remove the color cartridge the printer should function in black and white, though It will constantly nag you to install a color cart.
Posted on May 25, 2009
Can it (HP deskjet F380 all in one) still print with only color cartridge or only black cartridge ? Or Should two cartridges remain together to print even one is empty ? Thanks
the answer to your question is yes,it can still print with only one cartridge installed.
If you do not have a replacement cartridge, and the quality of your printouts is not a concern, you can still print in ink-backup mode. Consider the following guidelines before printing in ink-backup mode:
  • If you remove the tri-color cartridge, printouts will be in grayscale.
  • If you remove the black or photo cartridge, the product will print more slowly and the colors in the printouts will vary.
    press OK button to clear the error message like cartridge missing after removing one cartridge.
Jun 20, 2011 | HP DeskJet F380 All-In-One Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
My HP F380 all in one does not print at all even tho I just installed another (3rd) new black printer cartridge. Color cartridge is empty.
Stupid printers refuses B/W print jobs when color cartridge is empty. Sorry, the answer is: install full color catridge.
Nov 07, 2010 | HP DeskJet F380 All-In-One Printer
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
Greetings - have a full black cartridge yet prints green?
This printer uses all 4 inks to make black by default. You have run out of magenta in the color cartridge. Go to printing preferencies, Color tab. Check Print in Grayscale and tick "Black only" to disable color use.
Aug 14, 2010 | HP DeskJet 6122 InkJet Printer
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
Printer is only printing grayscale, need color, hp deskjet 6340
This is either because: 1. You only have black ink remaining and your tri-colour cartridge is empty or 2. In the printer driver settings you have selected either: Print Grey scale or Use black only.
I beleive your problem might be the last option.
To fix it :
1. Go to the printer driver (in vista go to: Start, Control panel, Printers, right click on your printer and select "printing preferences"). Now you are inside the printer driver. 2. go to the "color" tab. 3. Tehre you'll see if you have selected wither "Print in grey scale" and/or "Black only". 4. To ensure you get color again, de-select the"Print in grey scale" option.
Cheers, Ed
Oct 04, 2009 | HP Deskjet 6940 InkJet Printer
Hp deskjet 3845 won't print in color
When you click on "Print" and the window comes up, click on "Preferences".
Click on the "Color" tab. There should be an option to print in color or grayscale. Select "Color".
Oct 18, 2008 | HP Deskjet 3845 InkJet Printer
Printing problem
Have you tried changing the cartridge or refilling the black and colored ink cartridges?
Jul 25, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
213 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
