Question about Sony PlayStation 2 (PS2) Console
Cd draw wont close!....
The tray that slides out so i can put my game cd in is stuck and won't close....when i press the reset button it tries to close,but only goes half way!
  • 36 Answers
Try removing the buss cabel and den reconnect it..and better see if there is something stuck inside the rom..just to be precautionary..that must be the only problem..ok
Posted on May 25, 2009
Cd tray will not open er cd11 code
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
Jan 03, 2014 | Sharp HE CDDH950P Mini System
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Disk placed wrongly and cannot be read.
  • shut the computer off..
close to the eject button you will find a small pin hole
straighten out a paper clip and push it strongly into the hole and the drivr will pop open.. even if just slightly,, just pull out the draw and remove the disc.. close draw firmly and turn on pc..
the pin hole is there trust me..
Mar 18, 2010 | Acer Computers & Internet
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
My cd/dvd drawer open or close. was stuck open. now has closed an
You may force eject the CD tray by inserting a paper clip inside the small slot or you may force restart your computer by pressing the power button for 5 seconds.
Jun 10, 2009 | Microsoft Windows Vista Ultimate Edition
Something stuck inside disc drive
try this, press and hold eject button for around 15 seconds, this resets the cd drive, hope this helps
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
XBOX 360
you must do it manually be careful the CD is most likely stuck if you tried everything then there is no point then so just pull out in force hopfully the CD wont brake thats why i like the PS3 BETTER
Mar 26, 2008 | Microsoft Xbox 360 Console
Disc tray won't close!
i know this sounds carzy but mine just did that and i pushed it in hard but not too hard and then tried opened it and when i hit the close button it worked
Oct 27, 2007 | Microsoft Xbox 360 Console
CD tray stuck
Problem is very simple, Switch off system, unplug from mains. Open the Cover panel, and remoove CD. Close machine. Plug into mains. Open Tray, put in anothrer CD, enjoy your music.
Mar 05, 2007 | JBL Harmony Shelf System
Sony PlayStation 2 (PS2) Console Logo
76 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
