Question about Aiwa NSX-AJ300 CD Shelf System
Just trying to remove screen or take apart speaker box with out destroying the box
I was wondering how to take apart the speaker box or just take the screen off the speakers for the aiwa nsx-aj300
techman
  • 3130 Answers
SOURCE: Aiwa NSX-TR77
Well Jamez sounds like you have eather blown the soeakers or the output IC's inside the unit. If you have a meter you can simply disconnect the speakers and test the resistance of the speakers with an ohm meter. If you dont have an ohm meter then you can connect them up to another stereo or have them and the unit tested at a repair center. Sorry not really any serviceable parts in these systems. Good Luck
Posted on May 12, 2006
simplemitch
  • 752 Answers
SOURCE: No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Posted on Sep 22, 2007
djdizzys
  • 22 Answers
SOURCE: Just a question on specs for Aiwa NSX-5200 system
Hello I have had a look on the internet and found this for you it should let you download the user manual for free, good luck you should find out your specs
www.devicemanuals.com/company/AIWA-manuals-page9.html - 49k -
djdizzys
Posted on Feb 20, 2008
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
  • 135 Answers
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
http://www.donberg.ie/warehs/groupba.htm
try here
Posted on Jan 18, 2009
How do I open a UC-280 2.0CH USB Powered speaker system to reconnect the broken cable.
Once you open the speaker it will destroy the acoustic properties and make the speaker useless. The speakers are assembled with takp and glue and have to be pried apart.
Mar 14, 2015 | Audio Players & Recorders
Soundsticks ii apart
If there is no obvious way to take them apart...scres etc. taking them apart will destroy the acoustics of the speakers.
Apr 08, 2014 | Audio Players & Recorders
How do i take apart the speaker to fix it?
Generally the speaker can be removed from the box by taking the Grill portion off. Some are attached with Velcro and some with plastic pins on the frame that are pushed into the box. If a speaker is set in place with glue, you can't remove it unless you rip it out completely by hand. Some have screws and these are easy to remove. The speaker wires may be short, so take care not to rip out wires with the speaker attached. When you did the speaker replacement, place the speaker Grill (Front panel) back in place and you are done.
Dec 19, 2013 | RCA Audio Players & Recorders
I have a samsung subwoofer sealed box for an entertainment center, one of the wires came loose inside the box, how do i fix it
You cant fix it without virtually destroying the cabinet,as most active samsungs are glued together,designed to be replaced rather than repaired,sadlyUnless its a wire on the speaker,about the only removable part.Even the amplifier is inacessible on later models,such as the ps-we450 making any fault unrepairable.
Aug 09, 2010 | Samsung Audio Players & Recorders
Is it possible take the metal cover off the subwoofer speaker?
yeah, but its glued together pretty well, you will end up pretty much destroying the outer shell trying to get it apart
Mar 03, 2010 | Logitech X-230 Computer Speakers
Answering Delay.
get a TORX 6 screwdriver
WIggle the tiny flex cable connector
near the hinge.. still no luck ????
Buy another V220 on ebay
gently take the phone apart and sub in the whole
screen shell and front of keypad.
DO NOT TRY TO remove the screen from the body section..
you will destroy to the teeny tiny flex cable.
Google for V220 take apart/ disassembly
Jan 18, 2008 | Motorola Mobility V220
Motorola V220 camera
fuck you !!!! motorola sucks!!!!!!!!! samsung rules!!!!!!!!!!!!
Dec 21, 2007 | Motorola Mobility V220
Motorola v220 blank outside screen
take it apart
Oct 16, 2007 | Motorola Mobility V220
RE Blank screen
Aug 22, 2007 | Motorola Mobility V220
Repairing BOSE 901 IV series speakers
The grille will come off if you try to pry it off. Then, unscrew the bad driver. Sort of new ones are sold on E-Bay for not a lot of money. Install the new driver, secure it with screws, and snap the grille back into place.
Apr 24, 2006 | Bose 901 VI Main / Stereo Speaker
Aiwa NSX-AJ300 CD Shelf System Logo
466 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
