Question about Air Tools & Compressors
Pneumatic stapler leaks at the top
This is a cheap Chinese made stapler; however, it worked very well until suddenly it started leaking air at the top 'vent' when trigger is pulled. fyi--I bought this one in 2006 to replace my ancient Senco L gun when I couldn't get parts for it. It had the same problem.
I opened it up from the top and don't see any obvious problems with the many O rings.
  • 59 Answers
Your problem is you have blown a seal. On some of the cheap chinese guns, it might be a flat gasket instead of an o ring.
Posted on May 25, 2009
    President:
  • 2,976 Answers
Back down the air pressure. 30-40 psi should be sufficient.
LOOKING FOR SEAL REPALCEMENT AT TOP OF PISTON
Search Results
    [PDF]How to Repair you Nailer - Master Tool Repair
    www.mastertoolrepair.com/.../How%20to%20Repair%20you%20Nailer....
    Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
    Rebuild a Framing Nailer ' The Family Handyman
    www.familyhandyman.com/tools/air-tools/rebuild-a...nailer/view-all
    Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
    FASCO - Frequently Asked Questions - fasco tool finder
    www.fasco-tools.com/en/faq-manuals.html
    Search Tools by Application ... My Fasco pneumatic nailer/stapler leaks air from the
Feb 09, 2016 | Air Tools & Compressors
What should I do if my brand new Fasco pneumatic upholstery stapler is leaking air through the tail end...not the hose, but the two holes in the handle? Any suggestions?
Hi Anonymus,
What's happened if the driver blade has stopped in mid stroke, the air will escape. Quickest was 'round this is to take the airline off the tool, then find some scrap wood, place the tool on it as though you're firing it, and in THIS ORDER... pull the trigger and re-connect the airline at the same time. This usually sorts this out. Regardless of the tool make and model this will happen to most users sometime....
Leigh Co Limited
May 25, 2014 | Fasco Tools & Hardware - Others
Stapler leaks ouy of top
Try oiling it first. If it still leaks I would check the seal (reference #11) on this parts diagram.
http://www.ereplacementparts.com/senco-sns41-nailer-parts-c-117621_117622_117782.html
Mar 07, 2012 | Senco SNS41 16Ga Stapler 1" 2"
Air leak from trigger in bostitch pneumatic stapler
you need to replace rubber o ring on the trigger shaft pretty easy fix o ring is real small to deal with but doable automotive part stores usuly have assorted size in trays you can take old one out match its size .
Mar 31, 2011 | Stanley Air Tools & Compressors
Can not drive nails. Loud air hiss at top on tool
you have an air leak and you have to fix your stapler nailer hope its not cracked but just a seal
Sep 24, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
I have a central pneumatic palm nailer leaks air
sounds like a bad o ring inside the housing .
Jan 11, 2010 | Air Tools & Compressors
Air Leaking
bad or faulty seals quick fix might be to load it heavy with pneumatic oil and cycle it serveral times and the oil might make the gaskets seat.if not you willhave to replace seals.
Oct 26, 2009 | Tools & Hardware - Others
PNEUMATIC STAPLEGUN TROUBLE
First, undue the four cap screws that hold the manifold on, re: top of the gun, then remove the "driver blade", with needle nose pliers. There will be a little "***", grab it with the pliers and pull straight out.
Once the driver blade is out, remove the o'ring at the top. Wrap some teflon tap around the crack where the driver blade o'ring sits about two spins with the teflon tape, then re-insall the o'ring.
put back together.
Oil goes in the "air inlet fitting at the back of the gun where the air hose hooks up, just couple drops of pheumatic air tool oil, re: 30 weight non-detergent oil, like sewing mahine oil ect. its available everywhere.
Make sure you install the driver blade the way it came out, so "watch" as you remove it. If the driver blade is busted, or cracked you'll have to replace it, can get them at any tool store or on line. about 20-40 bucks.
should work fine.
UPR, Under Pressure Repair Ent.
Kelowna, BC Canada.
Mar 11, 2009 | Tools & Hardware - Others
MY PNEUMATIC STAPLE GUN WON'T WORK/ looses air through firing lever.How do I repair it? Where do I put the oil in?
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Air stapler leaks air through ''nose''
This sounds like one of the O-rings has failed. Yes it can be fixed. Check to see if HD has an O-ring kit for these guns. That kit will contain all of the O-rings as well as the lubricants for a total rebuild. That should resolve your problem.
Dan
Nov 12, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
193 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
