Question about Motorola Mobility H700 Wireless Headset
T-mobile Dash will not recognize 0000 passcode for H700 BT
After pairing my Motorola H700 bluetooth with my T-Mobile Dash it will not synch/recognize the passcode "0000" to establish a secure connection. Making it useless.
  • Jerome John May 11, 2010
    same problem here-someone plz help
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
HOW H700 BLUETOOTH CAN PAIR WITH SONY ERICSSON 750i MOBLIE ?IS THERE ANY SOFT WARE TO BE INSTALL IN MOBILE AND FROM WHERE I CAN SOFT WARE FOR H700 MOTOROLA BLUETOOTH. THANKS
Go into the phone's bluetooth settings and set it to search for devices, then press the answer button on the H700 for about 10 seconds or until the light stays on steady and your phone should pick it up as an available device if it doesn't work the first time, repeat until it picks up the H700 and use the code "0000" when prompted to complete the pairing.
Sep 16, 2009 | Ericsson Cell Phones
Light won't stay purple even when boom closed & button held
Depending on the phone... try and remove the current bluetooth device, if there is any. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
The boom should be open when you press the button.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Jul 19, 2009 | Motorola Mobility H700 Wireless Headset
Pairing my bluetooth
the solution was to replace my phone.i found out that it had been damaged by a previous owner.
Mar 21, 2009 | Motorola Mobility H700 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
How to pair up headset with cell phone?
first ul hav to press the button(big one) for a lil while..let the snap b closed...the light wud change to purple...then at the same time set ur bluetooth on the samsumg mobile to discoverable mode....snap open ur bluetooth and in ur mobile it will ask for a pass key which in default is 0000...then it will get connected
Thanks for using Fixya
keep me updated for further assistance
Jul 16, 2008 | Motorola Mobility H700 Wireless Headset
H700 bluetooth ear piece - Pairing with new phone
Press and hold the call button while the boom is in the off position for 4 to 5 seconds. The blue indicator light should come on and stay on. The unit is now in pairing mode. Initiate you phones feature of searching for bluetooth devices and pair the two together. The default passcode for the H700 is "0000" four zeros.
Good Luck
Jun 22, 2008 | Motorola Mobility H700 Wireless Headset
How to connect motorola skywing
Attn!!! Purple light wont stay on long enough to pair.
DO THIS:press hook button until light remains on solid (mic folded in)fold mic out while light is still solid then pair.
Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
1,098 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
