Will not read dvd, says loading, will stop and say no disc
I placed a dvd disc in player, it sys loading and after a few minutes it will stop and say no disc.
  • 4,234 Answers
If this unit is a DVD player, then try playing a music CD. If the music CD plays but hte DVDs do not, that is a good indication that the optics are starting to fail. Clean the lens using a cotton swab and alcohol. That will remove any film that may be on the optics lens. If that failes to resolve the problem, then the optics should be replaced. If you can update this with the make and model of the unit, I should be able to give you an approximate cost to repair this unit.
Dan
Posted on Aug 21, 2009
This problem can be caused by dust on the laser lens. Unplug machine, remove top cover, and clean lens very gently with a cotton bud. If this does not work, the laser is probably faulty.
  • 36 Answers
Yeah I ve heard many people saying this. It is mostly because either the disc is damaged or the dvd lens reader has been damaged ..that is the only way by how it says "no disc" so better check with some shop around..or with the authorized dealer itself..ok
Posted on May 25, 2009
SOURCE:
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Dvd takes 1 min loading ,then comes up can't read disc. I have tried to reset, then tried dvd again still takes long time to load and plays dvd once or twice for about a minute then stops, then goes back...
Optical lens needs to be cleaned with good quality cotton swab gently that will solve your dvd problem.
Unplug dvd player, take off top cover by removing its screws and clean optical lens.
Thanks.
Oct 30, 2010 | Sony Televison & Video
I have a Sansui Model VRDVD4000 and the DVD player keeps saying "load disc" even when the disc is in the player.
few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Some DVD players simply will not read/play home made dvd's, or dvd copies.
Apr 28, 2010 | Sansui VRDVD4000 DVD Player/VCR
I HAVE MY DVD PLAYER FOR ONE YEAR WITH NO PROBLEMS. NOW SOME DISCS WONT LOAD, AND THOSE THAT DO LOAD ONLY PLAY FOR A FEW MINUTES THEN STOP.
You may need to clean the DVD player's lens because it hardly reads the discs that is why you are experiencing that problem. If you have a disc cleaner, try playing it; having it spin for like 30 seconds will clean the lens. If this does not work, then you may have to manually clean the lens by opening the DVD's casing and unscrewing the plastic cover that protects the lens inside. Get a q tip or a cotton bud and damp it in an alcohol. Gently wipe the surface of your lens and let it dry for a few seconds. The return everything back and play those DVDs again.
Good luck and hope this helps.
Dec 12, 2009 | Sony SLV-D380P DVD Player/VCR
Keeps loading then says sys error
This appears to be an ongoing problem with Sony, and Samsung. I have a Samsung doing the same thing. The problem is when you load it, it is not fitting correctly into either the tray and or when it goes into place, it is not able to read the disk, because it is't spinning. You can usually hear it when it gets going. As it continues to turn, it will not let lens read it. It could also be the lens. If it is spinning and trying to read it and doesn't, you can try getting a lens cleaning kit. ,
Jul 24, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Won't pickup the dvd everytime
there are a few possibilties
1 make sure the disc is clean
2 your lens may need cleaning
3 some dvd players don't read burn copies of disc's some just read +R discs some just read -R disc
Jan 29, 2009 | Memorex MVDP1077 Portable DVD Player
"loading" message appears several minutes, then "no disc" message
check another disk.
or your dvd lens is weak to read dvd
i think it can read cds now.
if not, try to update firm ware or your dvd.
Jan 17, 2009 | Televison & Video
DVD Player won't open
Try this. This works on some brands and models.
Power up the unit. Using the remote, press and hold the 'STOP' button for about 5 seconds. Release and press the 'OK' button.
Jun 18, 2008 | Samsung DVD-V4600 DVD Player/VCR
129 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
