Question about Oster 76076-010 Hair Trimmer
Took blade apart on Oster Luckydog clipper and can't get it back
Can't get the blade back together on by Oster Luckydog clipper.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
  • talney6 Jul 04, 2011
    Putting the blades back together is very tricky. I took one apart when it was so built up with crud it could not get cleaned with solution enought to cut anything. If you have another blade it is helpful to look at it to see how things should stack up and the trick is to put the screws in part way first and then slide in the layers. But holding all parts in place can be a challenge. If you took the blade apart because it was not cutting well, chances are the blade is dull and will not work as you want even when put together. I purchased a new blade and was much happier.
Instructions oster power pro cordless clipper
go google and see if there is a workshop or user manual for the clippers
Jun 26, 2017 | Health & Beauty
I took my oster trimmers apart now i dont know how to put them back together can u help me
Unfortunately, Oster does not publish any real maintenance manuals. Basically, if you only took apart the cutting blades and the oscillator, it's not too hard. If you tried to take apart the electric motor, that's a whole different story. If it's just the blade assembly, carefully align the blade assembly with the groove pointing into the trimmer handle and hold the blades together so that they are parallel, not crooked and reinsert the screws. You will see how the blades align, based on the wear marks on the bottom blade guide. If you took apart the oscillating arm, then line up the cam pin with the round hole in the arm, then replace the screws that attach the top blade to the oscillating arm. You may have to push in the tension arm so that you can align the screws with the threaded holes on the handle first. Final step is to screw the bottom blade guide back onto the handle, again align the guide with the blades so that they are parallel and not crooked. The best way to do this is to start threading the screws, then before tightening them all the way, align the blades first. If none of this works, go to this website: http://www.osterstyle.com/CustomerService.aspx and locate an authorized Oster dealer/support center near you. You'll probably have to mail the clippers in to one of the sites.
JB
Feb 25, 2011 | Oster T-Finisher 76059-010 / 76059-030...
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
I took the blade apart and can't figure out how to put them back together. Can you help.
the oster clippers are usually mounted with spring tab to remove blade.Should be no reassembling. If there is, it should be a couple of screws that you screw in
Oct 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Jul 14, 2008 | Oster 76076-040 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
174 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
