Question about Sansui VRDVD4005 DVD Player/VCR
Can't see dvd on TV
Can't get dvd or vhs tape tp play on TV. Hooked cable up to coax "in", and ran cable from coax out to TV. DVD shows time elapsing as it plays. have set tv to channels 3 and 4. What am I doing wrong?
How to hook up to watch dvds
Posted on Jun 07, 2009
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
I can play DVD's but not VHS tapes. I hav checked all connections and several tapes to no avail. Thank you ! Ol' Fred
Hey Ol' Fred...
One of my good friends is an ol Fred so I felt compelled to stop in and help!
I'm not sure of your setup, but if you've got a combo DVD/VHS unit, make sure that you have out puts to the TV for Both parts separately... You can designate by accessing the TV's onscreen menu and setting up a separate source for DVD and one for VHS. I've found on my projection TV that it's best to use the Coax cable connections for the VHS to TV.
Then once it's setup with separate hookups to the Tv, you should have audio and video for VHS...
k
Dec 18, 2009 | Televison & Video
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
Insignia ns-lcd32-09 wont play VHS
Yes, that is correct you need composite (or coax) cabling to your TV. The unit cannot carry the VHS signal via component video or digital audio cabling
Feb 27, 2009 | Insignia IS-LCDTV32 32 in. Television
Can't get my VCR to work
FIRST!!! Make sure you have the coax or AV cables plugged into jacks marked out on the machine.....then....
*If you have it hooked up with a Coax cable, you should immediately have picture and sound when you turn it on. Make sure you have a dvd/vhs running and switch between channel 3 and 4. if this doesn't work, make sure that you have the cable connected to the one marked 'in' or 'cable in' or 'ant in'. then retry the previous steps.
*If you have it hooked up through A/V cables (Red/Yellow/White), make sure you have them all connected to the same set of jacks. They should be labeled Aux 1 or something similar and are generally surrounded by a box molded into the TV's plastic casing. You will then have to use the TV remote to switch TV/Video settings until you get to the one that matches the Aux jacks you have it plugged into. Again...make sure a dvd or vhs is running and keep flipping until you find a picture.
Hope this helps!!!
Dec 29, 2008 | GE 25GT240 25" TV
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
394 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
