Question about Samsung HL-S5086W 50" HDTV
Volume button doesnt work on my sky remote
I,v a Samsung plasma and at a time my sky remote used to turn the volume up and down but not now can anyone help??
  • 325 Answers
Please follow the steps below:
TV
RED + SELECT
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Posted on Sep 17, 2009
  • Mick Sep 17, 2009
    please follow the steps below:
    TV
    RED + SELECT (flashes twice)
    TV
    0060
    cheers
    Little Dish Fitter
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Sky remote control tv code
TV
TV
0060
cheers
Little Dish Fitter
Apr 11, 2009 | Samsung PS42E7HD 42 in. HD-Ready Plasma...
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Configuring Sky remote
3. Press tv again
Samsung Code: 0060
Sep 20, 2008 | Samsung AH5900092W Remote Control
How do I get the volume to work on my sky remote control?
I've just done this, guided by SKY but all you really need to do it....
Press Interactive button on remote
Choose option 5
Then choose set remote control, it should give you instructions and the correct cde fo ryou specifc tv
Good luck
x
Dec 18, 2007 | ViewSonic N2060w 20 in. LCD Television
Sky code for a goodmans gtvl19w17 hdv
Try this : Turn TV on, point remote away from TV, press TV button on your SKY remote...hold down SELECT and the RED key together for about two seconds, until the red light (LED) on the remote blinks twice...key in the remote code for your model of TV on the remote keypad ( for Goodmans, try 065, or 0335 ) then press SELECT button ( the LED should blink twice to show code accepted ) press SKY button to exit. point remote at TV and test.....Job Done . !
Nov 19, 2007 | Goodmans W280NS Television
50in Plasma 50PB6
TV
TV
0056
cheers
Little Dish Fitter
Oct 29, 2007 | LG 50PX5D 50 in. Plasma HDTV
Open Questions:
Samsung HL-S5086W 50" HDTV Logo
1,138 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
