Televison & Video Logo
A
Anonymous Posted on Jan 08, 2014
One for all codes list
I need the tv codes for a Sanyo tv. I have a one for all universal remote. I need a four digit code
Faith Goudy
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 06, 2014
Faith Goudy
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
310
Points
Code for orion tv, onefor all remote
5 Related Answers
Anonymous
  • Posted on Feb 10, 2008
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Anonymous
  • Posted on Sep 19, 2008
SOURCE: sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Anonymous
  • Posted on Apr 17, 2009
SOURCE: I need the 4 digit codes for Philips Universal
need code for rm 4912 remote control
liveone15
  • 61 Answers
  • Posted on Oct 22, 2009
SOURCE: I need the codes for a Sanyo tv
Go on line and get them.You should be able to get them on line.
Robert Kitaji
  • 1335 Answers
  • Posted on Sep 02, 2010
SOURCE: i digital universal remote RM-810 - need code for
Try 184 for the NEC TV.
Please rate this solution. Thanks.
2helpful
2answers
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
2answers
NEED A CODE FOR A SANYO CRT TV WITH A SANYO REMOTE
0854,0347,0223,0548,0532. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
What is the code for a sanyo tv
Hello
Five digit universal remote codes for Sanyo TV are:
10054, 10154, 10159, 11142
Four digit codes are:
0049 0097 0110 0004 0268 0012 0108 0180
Three digit codes are:
004/ 013/ 049/ 108/ 110/ 180/ 209
OK.
Wish You a Happy & Prosperous 2012.
Gopakumar G, Trivandrum City, kerala State, South India.
Ds19310 remote code
Hello
You are asking for universal remote codes for Sany I assumes, and posts this solution. Actually I didn't understand about your need. So I hereby send teh code list published by Sanyo. It doesn't contain any codes for TVs, at the email address you provided on your complaint post. Check and feel.
Five digit universal remote codes for Sanyo are:
10054, 10154, 10159, 11142 [codes with RCA RCR 312W universal remote control]
Three digit universal remote codes are:
four digit remote codes are:
OK.
32helpful
GE universal remote code for sanyo tv?
Hello
Three digit universal remote codes for Sanyo TV with GE remote are:
049/097/110/004/268/012/108/109
/ 013/ 180/ 209
Four digit universal remote codes for Sanyo TV are
OK
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Living solutions a17g0510 item # m#606426 big universal remote control. I cannot program it to my old sanyo tv
TV Codes listing:
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those dont work try the last three(or four) digits in the tv''s serial number. That's the only way could find my ATV TV's remote code.
What is the four digit code for the radioshack 3 in one low cost universal remote control for the sanyo tv?
The 4 digit code for the radioshack 3 in one low cost universal remote control for the Sanyo TV are 0154, 0088, 1907.
213helpful
15answers
Sanyo tv codes
Any ideas?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
