Question about Echo Garden
Lawnmower cuts out on fast idle + runs rough
Hi My honda eco hrg 41c lawnmower - starts up on chock but when I put it on fast idele - it cuts out# what can be the problem and how can it be fixed cheers phil
  • Jim Parker
    Jim Parker May 11, 2010
    How old is the mower and has any work been done on it?
    Jim
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Echo Master
  • 1,917 Answers
REBUIld carb it is dirty jet is clogged
Posted on Dec 17, 2014
#1 Taper
  • 1041 Answers
SOURCE: brand new honda lawnmower starts and runs fine then backfires
There should be 1 or 2 screws on the carb. You will probably have to remove the air breather to get to the screw(s). I've been seeing a lot of these types of questions, new equipment not running properly. Factory settings were not set properly.
When you find the screw(s), screw in a clockwise direction until it stops; DON'T SCREW DOWN TIGHT, JUST UNTIL IT STOPS. Then unscrew counter clockwise 1 1/4 turns. Try starting.
Continue this process, 1/4 turn at a time up to 2 1/2 full turns. If you forget where you are at on the turning process, start over by screwing back down. Then pick up process where you left off.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • 77 Answers
SOURCE: starts but when chock goes off stops running
OK take and check this. A lot of the honda engines,especially push mowers,tillers and pressure washers,they put a type of coating inside the gas tank. The bad thing about this type of coating is it has a tendency to peal and wash into the carb. I would look inside the tank to see if there is any debris. I would also clamp off the fuel line and take out the bolt that holds the fuel bowl on and catch the fuel that drains out in a clean tray. If it looks dirty,pull the carb and clean it,it should fix it.
Posted on Aug 09, 2009
  • 279 Answers
SOURCE: Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
Posted on May 28, 2010
  • 4 Answers
SOURCE: i have a honda o
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Posted on Sep 25, 2010
  • 130 Answers
SOURCE: I have a MTD Honda Lawnmower that is having idling
Generally this indicates a "lean" condition in the carburetor and there are no adjustments. Depending on your abilities, the best fix is to remove the carburetor and clean all the metering passages/jets. In some cases you are better off just replacing the carburetor. I have seen some Honda carbs. as low as $15-$20. Hope this helps to some degree.
Posted on Mar 08, 2011
After start it backfires, sputters then runs
Hi,when starting bike you put the chock on,remeber this is to make a richer mixture for cold start,so when you start the bike put put the choke off a little bit as it warms up,other wise wat you are doing is couseing it to floud,so again as the bike warms up put the choke off little bit at a time,all the best.
Sep 01, 2015 | Honda VT 1100 C2 Shadow Sabre Motorcycles
It idles rough at all times. Changed motor mounts help some. Run great after idle.
idel my be set to low turn up a bit take it up to 950and check the timeing
Apr 21, 2011 | Honda Accord Cars & Trucks
1992 4runner idels rough sometimes
Check the intake hose to make sure that it doesn't have a whole in it also check the air box that the filter goes in also. Mine was idling rough also and we found a whole in the filter box and the intake hose had a whole in it. Hope this helps.
Feb 23, 2010 | 1992 Toyota 4Runner
2005 superduty- 6.0 Started ideling rough all of
a misfiring engine wont have enough power to sustain a load thats why when you shift it dies.you need to retify the problem first.check for any presence of water in the diesel fuel.Not enough fuel pressure
Jan 20, 2010 | 2005 Ford F 350 Super Duty
Rough idle then stalls
Vacume leak or bad idle motor. With the car in park and running with the hood open listen for leaks moving your hand around the different hoses looking for a change in the sounds that you hear. The idel motor also makes the car idel up to 1500 RPM or so right at start-up then idel down, If it doesn;t the idel motor is likly. Check engine light is on when running? Test for codes, Follow code test charts don't skip any steps!.
Nov 02, 2009 | 1998 Chevrolet Malibu
Rough idle(200-300RPM)off idle runs great no white smoke
Have you changed your fast idle valve or air idel control valve I would change the air idle valve because it is the one with an electric sensor.
May 22, 2009 | 1990 Honda Prelude
Rough idel when cold start
if u have a damaged plug it can be running on 1 less cylinder ,it will idle very rough,change it!
Mar 26, 2009 | 1993 GMC Safari
Idle probs
Check your idle control valve. You might have to replace it, 80-90 bucks new. Or see if there is an air leak from the intake manifold. had the same problem.
Jun 04, 2008 | 1992 Honda Prelude
Open Questions:
Garden Logo
845 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
