No longer turns on
I have a Samsung model LNT2653H purchased Jan 2008 that suddenly no longer turns on. The red LED turns on and the blue light turns on, clicks, and then turns itself off. There is a fuse (T6.3AH-250v) but I?m assuming it is OK since I appear to be getting some power (LED and blue light). I've researched and found many issues with power supplies and bad capacitors on many Samsung models. After opening the chassis and visually inspecting the capacitors (CM851, CM861, CM860, CM858, CM856, and CB852) they all look fine with no leaking for bulging. They all appear to be 1000uf but various voltages (10v, 25v, and 35v). Should I try to replace all the capacitors, or just replace the entire board (BN44-00192A)? I?ve read that Radio Shack stocks them and they are inexpensive, so I?m thinking it is worth a shot to try and replace them. Any advice? Could it be something else? Thank you.
  • 5 more comments
  • jklinken May 25, 2009
    Thank you. I'll give it a try and see what happens. If it doesn't fix the problem and it is one of the other causes that you describe, I will probably just replace the board since I'm not sure how to diagnose and replace a transistor, diode or electro caps. Thanks for the quick response.
    Great info... thanks....
  • jklinken May 26, 2009
    I replaced 6 capacitors (all but the 2200uf which Radio Shack didn't have) and no change. Unless someone can think of something else, I guess I need to replace the entire power supply board (BN44-00192A) Any thoughts?
    This is a 26" Samsung LCD model LNT2653H about 1 1/2 years old.
    I'm afraid testing the diodes and transistors is outside my knowledge. I think I'll just replace the power supply board at this point since I found them on ebay fairly inexpensive. Thanks for the help.
  • jklinken Jun 04, 2009
    I replaced the power supply board and now I get no power at all (no lights come on even for a few seconds as before). The part number that was shipped is BN44-0156A instead of BN44-00192A. It has all the same connections but I'm not sure it is actually interchangeable. I'm not sure what to do at this point. I hesitate to sink too much more money into it as I'm sure a professional repair will run into the hundreds, especially if it needs to be shipped. A new 26" tv is around $400. Any advice would be welcome.
  • fougzki May 11, 2010
    Is this a tube or CRT type television?
  • 230 Answers
It's well worth replacing the capacitors, but this problem can be caused by a short on the power supply (Which is what the caps do). Most shorts that arise in power supplies are result of a shot transistor or diode and of course the electro caps. Check these while your changing the caps.
Good luck with it.
Posted on May 25, 2009
  • 2 more comments
  • Dudeman321 May 25, 2009
    Electro caps are the ones you have been looking at. Diodes are easy to test just put multimeter in ohms x1 position and get big reading one way none the other (if they read big reading both ways or none both ways then its stuffed) Transistors are a little more difficult you need to put one lead on the base and the the other on emitter and then collector or vise versa. Should look like a diode, if you reverse the leads it will go to a high reading. Somtimes you can measure another diode between colloector and emitter. The important thing to look for is short circuits, with the fault your having so the meter will shoot up, if you read 450-550 this is normal for a diode or transistor.
    No probs mate, glad to help.
  • Dudeman321 May 26, 2009
    A tube is the nickname for a crt, however your machine is a rear projection. They use a tube for every color (RGB) and project it to the viewer.
    Sorry i did'nt read your posts correctly, its an lcd tv. So in answer to your question its neither. I gues its time to test the diodes and transistors. lol
    No seriosly just start disconecting stuff from the main power supply it will help isolate the fault.
4 Suggested Answers
  • 6 Answers
SOURCE: capacitor size
You can get any size/type capacitor from DigiKey.  See this thread for the part numbers I used: http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Nov 09, 2008
  • 899 Answers
SOURCE: i want to replace four capicitors in my Samsung LCD TV
yes that is ok to upgrade to the 35v 1000uf cap
Posted on Jan 04, 2009
  • 517 Answers
SOURCE: my FLM373B picture is psychedelic and it's
Good day Sir!!
A T-con board has something to do with the problem in colors and image of the TV...
it is usually reddish,pinkish or had a double or shadow image....
Had you try to play a record movies or dvds so that we can surely determine it has something to do with the T-con board or in the other parts or in signal...please play one then tell me if it is still having the same problem..
Thank you...I will wait for your comment...
Posted on Aug 06, 2011
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Dec 19, 2015 | Samsung ML 1610 Laser Printer
Samsung HL61A skin color is green
Need complete model #--to determie if this set uses an LED light source--if so--the red and blue LED';s have failed.
Mar 13, 2014 | Samsung HL61A750A 61" HDTV
I have 42" ,Sansui plasma tv .model number Sty 0342 . when i switch it on , the power led chages from red to blue, then suddenly goes red again .i've changed the power board but it keeps doing the same...
I have sansui television 42"model number STY0342, plasma 3D.when l turn it on sometimes it takes time to switch on after turning it on.it will change the standby light to blue.what might be the problem.
Dec 26, 2013 | Televison & Video
How can i get the red light on my kaider speaker to turn blue?
You can purchase LED red and blue emergency strobe light for your truck for $35.99 with free shipping online at http://www.gadgettown.com. ------------------------------------------------------------------------------------
Original Launch X431 Master
Mar 06, 2013 | Cars & Trucks
Can't turn on TV
Since when does 2 years equate from purchase date of 2008 and the date at present 2017.
Probably a power supply issue caused by leaky capacitors.
Apr 04, 2017 | Samsung HPT5054 50 in. HD-Ready Plasma...
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
Energy S 8.3 Woofer; blue led doesen't light up
Bought a S10.3 in jan/2010, LED died a month later. I've repaired it by myself. After inspecting circuit, I've found that their design puts almost 14V of reverse bias upon that poor blue LED. These components are not usually expected to sustain more than 5V of reverse polarization. So, in my opinion, there is a design flaw. To make a long lasting repair, you just need to insert a general purpose diode in series with the LED, such as an inexpensive 1N4148 ($0.05). And, of course, any readily available 3V, 5mm, through-hole round blue LED (I think crystal clear should be better).
Sep 09, 2008 | Energry Speakers Energy Speakers S8.3...
Televison & Video Logo
1,043 people viewed this question
Top Televison & Video Experts
Electro Med Services...
