Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius 1100
Symptoms are no power to the machine
  • joe90uk Aug 13, 2008
    no power to machine, fuse is fine socket works.
  • Anonymous Dec 28, 2008
    hi i have hotpoint 1100 aquarius washing machine and the door lock inside the washing machine keeps on moveing out of position causing it not to work so have you a answer for me please
  • 64 Answers
Did you check the plug top fuse? Try plugging a reading lamp in to check you have power. If you have, suspect the on/off switch or the door interlock micro switch, or a burned out wire to either
Posted on Oct 21, 2007
My hotpoint aquarius 1100 will not drain out water, i have tried to clean filter at back. what else could it be?
clean up , seal up presure pipes for level switch , dont know your machin but most of them have it
Dec 08, 2010 | Hotpoint Washing Machines
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a Hotpoint Aquarius 1100 washer dryer and think the filter might be blocked but I cannot locate the filter to check it. Any ideas?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean the plasic filter inside hose..
Also check the pump for a blockage as well.
Thisn should solve your problem.
Dec 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
No manual
HI. i have located the manual and you can access it via the link below. You can also print it out if needed.
CLICK HERE FOR THE HOTPOINT MANUAL.
Please rate and god bless:)
Apr 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Can you please give me part number, price & delivery on an on - off switch for a Hotpoint washing machine WF215 1100 SPIN AQUARIUS. Thank you, hamolloy@gmail.com
Try these sites for spares, what you asked for is available here:
RepairClinic.com espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 01, 2009 | Hotpoint Aquarius WF215 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
probably not door switch, but to access, remove door gasketf rom cabinet in area of door switch and door switch is only held by 2 screws. more likely to be the suppressor capacitor. remove top and look at suppressor - they sometimes go pop
Aug 17, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
616 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
