Question about Vehicle Parts & Accessories
Pink wire is for what
What is the pink wire Connected to Spy car alarm
  • ron_borchard Jun 01, 2009
    could u help with other colours ,PLEASE
The pink wire on my system connects to the siren.
Posted on May 30, 2009
My screen. On my valor is not working at all can not see anything , but radio works fine. What is wrong please help
  • If you haven't found the answer (or your like me and you found a post because you were looking for the same answer)...
  • Is the PINK wire connected to GROUND? (Legally in most states it should be connected to something that is only at GROUND when the vehicle is in PARK). When this wire is not at GROUND potential the video screen does not come on and stays black in any of the VIDEO modes.
  • When the source is RADIO the screen will function no matter what pink has going on.
  • The PINK wire is a NEGATIVE ENABLE but I don't know if it knows it.
  • When source is DVD with a DVD loaded you should hear the audio even thought the screen is black, of course if its sitting on a DVD menu with no sound you won't really know.
  • This is a PINK wire coming from the head units modular plug. not the bundle of wires that comes through the grommet but the plug that is removable. Not to imply that I have ever seen another pink wire. Well once I drank a lot of tequila ... not a pink wire. never mind.
  • While the wire was labeled on the OEM harness I have seen, the OEM wiring diagrams I have seen only have the description "PARKING" but no color code.
  • Feel free to repost or contact if the pink wire is grounded and the video screen is still acting the fool.
Sep 02, 2015 | Valor Car Audio & Video
I had a avital 5303 installed on a 95 Riviera now I'm having problems starting the car it will crank but Will not start how to bypass the alarm system uninstall or somethin
first check if on the alarm are connected a green and a purple heavy gauge wire to a yellow or purple on the car normally this is the starer but if you see the purple and green from the alarm conected to a pink in the car thats where you going to do the bypass of ignition but if its not connected to this than you have other problems (coil,fuel pump.or security key problems
Jun 29, 2015 | Avital Vehicle Parts & Accessories
Fitting SPY 5000m Alarm Suzuki Bandit 1200 NOT WORKING
wiring diagram would be helpful if theres a link, have you taken the ignition power source from before or after the switch. i.e does this need a live continual power or just on power.
Mar 10, 2013 | Motorcycles
What the best way to connect the pink wire to the parking brake system?
do not connet the pink wire to the breke system , i connected to the ground cable (black and pink together) and it play perfect you drive you see
Feb 09, 2011 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
How do i wire in a alarm on my 97 suburban K1500 i need a wiring diagram to find wire colors for windows lights and etc........
1997 Chevrolet Suburban Car Alarm Wiring Instructions
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Purple or Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Pink/White Or White (This wire must be connected as ignition #2 for remote starting.)
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Drivers Kick Panel
Power Door Lock Negative Wire (-): Light Blue (Type A)
Power Door Lock Negative Wire Location: In Either Door Harness
Power Door Unlock Negative Wire (-): White (Type A)
Power Door Unlock Negative Wire Location: In Either Door Harness
Door Trigger Negative Wire (-): Purple
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: White (-), Requires Relay
Domelight Supervision Wire Location: At Headlight Switch
Trunk Release Negative Wire (-): Black (+) Or Black/White (Requires Relay)
Trunk Release Negative Wire Location: At Hatch Release Switch Or Low In Drivers Kick Panel
Horn Negative Wire (-): Black
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): White
Tachometer Wire Negative Wire Location: At ECM. The ECM (electronic control module) is located on the driver side inner fender.
Wait To Start Wire: When hooking up a remote starter on a diesel, you will need to program in the 5, 10 or 15 second wait to start timer in the installation manual. On some vehicles the wait to start light on the dash is not a true (+) positive or (-) negative and the wire from the remote starter will not work.
Wait To Start Location:
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Mar 31, 2010 | Brand Remote Start/keyless/car Alarm Very...
Vm 9022 jensen how to connect a pink wire
i am not too sure what u realy want. but if the pink wire is connected to the parking brake u can only view videos when the parking brake is engaged but if you want to view videos all the time or anytime just disconnect the pink wire from its current connection and reconnect it to the vehicle's chasis
Nov 26, 2008 | Car Audio & Video
Kenwood kvt 617
the pink wire is for a cell phone mute if you are not using a hands free kit with a mute then this wire needs no connection
Sep 25, 2008 | Kenwood KVT-617DVD Car DVD Player
Vehicle Parts & Accessories Logo
113 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
