Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
Black & Decker gh400 GrassHog will not autofeed line. Spool is wound correct direction and properly inserted. White plastic ratchet cog underneath the spool looks good and toggles freely while disassembled. I think the cog remains in the "out" or locked position after the spool stops spinnig, instead of returning to the "feed" position and letting the spool advance one notch.
  • kevinaires May 25, 2009
    After two years use, autofeed does not work.  Some conditions as first post.
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
SOURCE: how to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Posted on Nov 16, 2009
vincob
  • 718 Answers
SOURCE: how to string spool for black and decker corless
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Posted on Apr 08, 2010
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
  • 3 Answers
SOURCE: ENGINE WILL NOT ENGAGE WITH SPINNING SPOOL
I had the same problem, The pully is plastic and is mostlikely melted. I took mine apart when it finally stopped working and found that the belt had broken as well. When taking it apart, there is a hidden screw under the black sticker label. Just feel for the soft spot. Also, there are screws under the black plastic embelishments.
Posted on Jun 02, 2010
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
I have a Black and Decker Grass Hog trimmer and I can't get it
There is only a couple of reasons that I can think of that would cause this
1. The string is wound the wrong direction; it should be wound clockwise on the spool. (This is my bet.)
2. Or maybe, the string is too small for your particular trimmer, but this is very doubtful.
Jim
Jun 18, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
SPOOL
You have the string wound the wrong way. Wind in the other direction.
Jim
Jun 16, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
May 07, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
1,322 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
