Question about Cameras
How do I use the IR Remote Controller on my Toshiba PDR-3330 Camera. The manual is not very clear.
  • 1 more comment
  • cssoleto May 25, 2009
    How do I get in the Capture mode. The manual doesn't mention Capture mode. I wish Toshiba would try to read some of their manuals before shipping them.
    That worked. I was standing too far away from the camera for the IR device to work. You must be no more than 4 feet from the camera for the IR Remote Controller to work. Toshiba needs to point that out in its manual. Thanks. Chet Soleto
    Brigadier General:
  • Cameras Master
  • 3,614 Answers
The camera provides IR Remote Controller, which works as the function of shutter release button in Capture mode. In case of self-timer is active, the picture taken will be delayed 2 seconds after getting IR Remote controller signal. It will remain the same mode until you manually press Self-Timer button once again to exit from the mode. (Burst photography is not possible.) IR Remote controller works as forward button in Playback mode to change picture to next one
mean:
Shot after 2seconds / Getting IR controller signal
Posted on May 25, 2009
  • micromaster
    micromaster May 25, 2009
    try to perform each steps:
    • Manually press Self-Timer button (once again to exit from the mode).
    • the picture taken will be delayed 2 seconds after getting IR Remote controller signal.
    • IR Remote controller works as forward button in Playback mode to change picture to
      next one
PDR 3330 WILL NOT TURN ON
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Oct 21, 2009 | Toshiba PDR-3330 Digital Camera
Lost memory card
Why can't you use a different card? Just put it in and format the new card in the camera.
Rob
Mar 11, 2009 | Toshiba PDR-3330 Digital Camera
Misplaced USB Cable for Toshiba PDR-3330
The USB cable for cameras is easily availalbe at most computer or camera stores. You can take your camera along just to make sure one end fits properly to your camera.
The USB cable would have mini connector on one side and a standard male connector on the other side. (cost around $7~10)
Please rate our solution and thanks for using FixYa!
Mar 05, 2009 | Toshiba PDR-3330 Digital Camera
Toshiba PDR-3300 Lens cover message
Hi Judy, thanks for coming to FixYa.
Sorry no one has gotten to you sooner. Your manual mentions this and this is what it says to do:
Turn the camera on and move the lens cover switch to the open. Then your camera should operate normally. Let me know if that helps.
Rob
Feb 16, 2009 | Toshiba PDR-3330 Digital Camera
What kind of SC memory card do I need to get for a Toshiba PDR-3330 digital still camera?
The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
Aug 22, 2008 | Toshiba PDR-3330 Digital Camera
PNY 2GB memory card
I have the same camera and bought a 4GB PNY SD card and it wouldn't work, so I read the manual :) The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
Hope this helps! -Kim
Jul 15, 2008 | Toshiba PDR-3330 Digital Camera
Toshiba PDR 3300 Menu Controller
To select you need to press the enter button which is not clearly marked anywhere on the camera or in the manual. It's the toggle button press the center of the toggle button this is the enter button and should solve your problem. It took me a while to figure it out.
Jun 27, 2008 | Toshiba PDR-3300 Digital Camera
Need old drivers and software for Toshiba Pdr-2 digital camera..
Hello , I am in need of software for my toshiba digital camera PDR 3330. I need to instal the pictures to my pc. can't find any software , please help......... where can I get
Apr 19, 2007 | Toshiba PDR-2 Digital Camera
Using the Remote Control
With the camera turned ON, Press the TIMER button and select two or ten seconds. The camera will remain ON and you can use the REMOTE CONTROL to take pictures or start recording AVI Movies. You do not have to reset the camera, just press the remote control again to continue taking several images. Now you can be a part of the action and pictures.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
