Question about JVC KW-AVX710 Car Video Player
KW-AVX710 Screen stays black (off) untill I hit the open button
I installed a jvc kw-avx710 that I bought from a friend in my 2002 Corvette Z06. When I turn my key on the only button that does anything is the open button, which then the screen turns on and allows me to put in or eject discs and close it again (the buttton and the touch screen seems to work fine). I tried reseting it and it does reset. But basically the screen never comes on unless I hit the open button, no other button seems to make the screen come on including the power button.
So I decided to verify all the connections after I got frustrated with it. Everything was correct except one wire that was on the new harness I got that for my car that was labeled "12V fused" (supposedly the key on power source). I tested it with my volt meter and it did not have power at any time, even with the key on. The constant power source wire was hooked up so that's why I was able to open the face and eject CD's and DVD's but not do anything else (like when your ignition is off). So I ran a new wire from my fuse panel and everything works now. Just like my Thermodynamcis professor says "nullius in verba" (take no one's word for it), just because the wire was labeled doesn't mean it's right! Hope this helps.....
Posted on May 26, 2009
Jvc kw avx840 frozen on telephone screen. Press reset and everything works fine again until either detatch facia or switch off ignition.
Sounds very strange ... I have the exact same set. Try removing the Bluetooth dongle and re installing it again and see if this helps. Is this a new install? You r ground is good right? to the frame not just a black wire from old stereo you replaced?
Apr 21, 2014 | JVC Kw-Avx840 7 Double-Din Multimedia...
MY SCREEN IS CRACKED CAN I GET ANOTHER
Yes you can get another but do search properly, as there are n number of fake business of electronics items on google
Apr 18, 2013 | JVC KW-AVX710 Car Monitor
Open button not working how do i eject cd
You should find a small pin sized hole on the face of the cd player that allows you to poke in a paper clip to release the cd
Sep 19, 2011 | JVC KW-AVX710 Car Monitor
My jvc kw-avx710 video is not playing... i looked at the trouble shooting and i found i need to connect the light wire to the parking brake. but i need to know what wire do i connect the light green wire...
You could just simply hook up a small switch so that the unit "sees" a constant ground. You will more than likely have to do some sort of combination in order for this to work. If you look in the manual, it should show you the correct combination. Instead of using the parking brake, you would use the switch. It might be possible to wire it directly to your ground wire. The thing to know with these methods is that you cannot drive around while watching.
Apr 14, 2011 | JVC Car Audio & Video
JVC KW-AVX710 not save. after switch off the car .when start it again all settings become to default
If your unit is not maintaining it's memory, it may be associated with the lack of a constant 12 volt power source. Test the units yellow wire, it should rest at 12 volts with the key in all positions; off, acc, on/run, start. This yellow wire should be connected to the vehicle's battery wire. Also, test the red wire. This wire should be connected to a switched 12 volt power source. It should read 12 volts with the key in accessory and on/run only. If you used a vehicle specific wiring harness to complete the installation, the wires may be switched in the harness. It's not a common issue but, I have seen it happen.
Dec 04, 2010 | JVC KW-AVX710 Car Monitor
JVC KW-NX 7000, the spring loaded latch for the detachable face is broken so the face plate will not stay on therefore I cannot use my unit. Can I buy a new latch for this and if so where or do I have to...
If you still need help on the display faceplate, check this guy on ebay, he has all the jvc parts, I bought my faceplate touch screen from him, his user id is genecyrus on ebay NAU0005-001X
Oct 18, 2010 | JVC KW-NX7000 Car GPS Receiver
Touchscreen won't respond when touched. All other functions of unit work. Do the screens just go bad and where/who repairs this?
you may need to reset the unit. after that do a screen recalibration. if that doesn't work the ribbon cable could be broke
Jan 26, 2010 | JVC KW-AVX710 Car Video Player
Bypass parking brake
Does the suggestion by djBass work with the avx800 too?
Feb 16, 2008 | JVC KW-AVX800 CD Player
JVC KW-AVX710 Car Video Player Logo
510 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
