Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Motor slows down and makes burning smell
When I turn the vaccum on, the motor sounds like it is winding down and there is a burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
Posted on Aug 16, 2009
    Problem Solver:
  • 15 Answers
Make sure the belt is ok.
Check and make sure that you are not clogged
Posted on May 25, 2009
Miele vaccum cleaner wont run
If dirt or other debris collect around the armature of the motor the stator will no longer communicate and turn. Usually the brushes wear down and need replacement also. Once you replace the brushes and clean the interior of the motor housing, the motor should start up again. AS long as there is no smell, the motor parts are still in tact. You will also need to replace the belt from the motor spindle to the brush.
Feb 17, 2018 | Miele Vacuums
Is there a fuse or circuit braker in a sunline SM-G31 grinder?
Hate to say it but I fear the windings have burnt and is in need of repair. Any burning smell or smell of heating is most of the time directly related to armature or burnt brushes. If this grinder suits your needs having it rewound would be profitable.
Mar 26, 2016 | Vacuums
Burning smell and power dogs down
electric cable damaged, get new vaccum cleaner
Apr 20, 2013 | Fantom Vacums Vacuums
Hello, I have a problem with my Eureka Powerline bagged upright vacuum. It has a 12 amp motor and is model #4352, Type D. It was probably bought new in 1998. My problem is, while vacuuming today the motor...
it sounds like a rubber sealing in the motor has come loose and is being constantly rubbed against the walls of the motor with would cause the smell and loss of motor speed caused by the fricton of rubber against the rod so if you can get to the motor try to open it and see if you can get it if not take it to a small engine repair service hope this was helpful:)
Nov 16, 2009 | Vacuums
Wind tunnel two with bag, started with burning smell then shut off with red light on. Belt is fine but cannot get it to start again.
Sounds like your motor.Try replacing the brushes in the motor.If that does not work then the windings in the motor have burnt out.
Aug 01, 2009 | Vacuums
Wertheim vaccum 3180
most vacuums use a belt that runs from the motor to the front brush. and when the brush gets jammed the motor continues to run and burns the belt (probably what you smelled).
you'll have to turn it over and remove the base plate and replace the belt.
use the old belt to find a match
hope this helps.....jay
Mar 21, 2009 | Vacuums
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Vaccum stops cleaning after a while it shuts off
Sounds like the motor is overheating and thermalling out (Hight Temp shut down). This could be caused by overfilled cannister, obstructed passageways, or debris accumulated around the motors cooling fan. Try emptying the catch container and blow out / clean all the filters. Check for obtructions by going to the hose mode and alternately blocking and uncovering the nozzle end - feel for good suction and listen for a definite change in motor sound (Pitch Change) With the intake open, the motor should rev freely, when blocked it will slow and sound labored / loaded down. Another possible cause could be a binding brush roller overloading the motor - but this will usually burn out the belt first. Notice any unusual smells? Burned belts stink like burnt rubber.
Jun 01, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
458 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
