Monitor darkens down every few minutes. It relights when i open and close lid.
    Scholar:
  • 145 Answers
Could be your power settings. Some new laptops adjust screen brightness due to ambient light.
Posted on May 25, 2009
Won't heat up above 200 degrees.
Try turning off the valve to the tank, then leave the knobs on the grill open for 2-3 minutes. Turn off the grill knobs, slowly, slowly open the valve on the tank. Relight the grill and see if it gets hot.
Mar 26, 2014 | Broilmaster Premium P3 Grill
Stoves newhome gg700 grill flame goes out if lid is closed
I had a stove in my camper that did this. The answer was to let the flame burn for a few minutes BEFORE closing the door. I think the original problem is that there is too much gas flowing to the burner and it literally blows itself out, until you get everything heated up and working. The question, I think, is there a way to turn down the gas pressure??
Nov 19, 2013 | Stoves Newhome ECH600MXa Electric Kitchen...
Computor turns on but no screen appears
Disconnect the mains, remove the battery, press the power button for a few times, leave the laptop for a few minutes. Put the battery back in, reconnect the mains, turn on the laptop.
Check that the cover sensor is not obstructed. (either a pin/extrusion on the lid part that presses down a button when the lid is closed or a pin on the keyboard part which is released when the lid is open. Other sensor types require disassembling a laptop to diagnose).
Look carefully if you see a very dark image on the screen (backlight is broken).
Try to connect an external monitor (if the picture appears on the external monitor, then either the cable within the laptop or the screen of the laptop is broken, disassembly required). If no picture appears on the external monitor, or the image is scrambled, the videochip of the laptop is broken. Disassembly required.
Due to the age of laptop, repairing at the workshop might be not economically viable. If you have important information on the hard drive, you can copy it by connecting your hard drive with a ide/sata to usb cable to another computer and saving the data.
Oct 24, 2013 | Acer Aspire 5100 Notebook
I have a Dell Inspiron 6000 laptop (15.4 in display). Its a close to 5 yrs old. I upgraded to 2GB RAM. Its running Win XP with SP3 I am having problem with my LCD monitor. When I press the power button,...
If you see a very faint image at the laptop's LCD screen, it is possible that the Laptop's LCD lid close switch is stuck in the closed position.
In this mode the back-light stays off, even with the LCD lid open. This is to conserve power when the laptop is ON with the LID closed.
Check the LCD lid close switch. It is a small plastic pin located close to the back LCD hinges. Try tapping the lid switch a few times to see if you can turn on the screen back-light. If that does not help, then I would suggest to replace the FL inverter board.
See the layout picture below.
Hope this helps.
Jun 26, 2010 | Dell Inspiron Notebook
YOU GUYS ARE GREAT SO FAR
What you describing here is usually caused by one of the coils that 'opens' electrically when it gets hot. The coil is simply a small wire of significant length. A piece of the wire is broken, but when cold makes contact, as it heats up with use it separates and will not allow electricity to flow through it keeping the solenoid activated.
The cool down time may be a few minutes to a few hours to never between times it works the first time and the next time.
Apr 23, 2010 | Whirlpool Dryers
Oven doesn't work, but stove does
Once I opened the lid, the oven reset itself. I then closed the lid and it went off again. I did this again (lifting the lid), and the oven again reset it self. I fiddled with the wiring to the stoves and the bundle of wires, and when i closed the lid again, it did not shut down. It has continued to work.
Dec 13, 2009 | Kenmore Ovens
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
My view sonic monitor is turned on and then in a few minutes it turns off leaving me a black screen. what can i do to fix it?
Sounds like overheating of something inside. Open the monitor, get access to PCBs and observe for darkened areas especially over the power supply and inverter. Also that long working before shut down may tell about bad solder junction, also caused by constant local overheating - look for those with tiny cracks, especially over darkened areas on PCBs.
Most likely - that's the source of problem with your monitor. And, as far as you open the monitor, check for any popped electrolytic capacitor - never bad to replace them too.
Sep 14, 2009 | ViewSonic VX1935wm LCD Monitor
Weber grill will not heat up, reaches 200F and no higher
Also, it has to shut down the same way every time you use your grill.
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Jun 28, 2009 | Weber Genesis Silver C Grill
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
