Question about Packard Bell AudioDream MP3 Player
Audio Dream512 mb player gives of noise like a coffee percolator.
  • jds5376 May 25, 2009
    used 3 sets of phones, and 1 pair portable speakers. Problem is in the unit.
    jds
The headphone they do not work
Posted on May 25, 2009
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
How hot should the coffee be in a Farberware percolator
It should be about 180 degrees. The percolator should perc about one minute for each cup of coffee. If it stops too soon and the water is not hot, then the thermostat is bad. The thermostat can be replaced.
Feb 06, 2014 | Faberware FCP280 Coffee Maker
Makes popping noises
If the wires are shorting out you would either experience a power interruption, circuit breaker or fuse blow, and/or a smell of some sorts. If this is under warranty I suggest you turn it in for a new one. On the other hand, remember it is a percolator device and when water is heated to the desired temperature the action is for the hot water to rise and flow over the basket containing the coffee grounds. Percolation makes a popping sound, at that is a normal condition.
Dec 22, 2013 | Cuisinart CHW-12 Coffee Plus 12-Cup...
Farberware millenium coffee percolator does not heat
There is a thermostat in the bottom of the percolator that is broken. It would normally cut in to perc the coffee and then cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to bypass the thermostat and just unplug the percolator, time it for 1 minute per cup.
Mar 04, 2013 | Farberware Coffee Makers & Espresso...
What is a coffee percolator?
A percolator is a type of pot used to brew coffee. They are not used very much nowadays, since the introduction of other methods such as the drip, French press and espresso machines.
Feb 07, 2013 | Wine & Spirits
Maui outlets for Farberware percolator do not carry filters? Why?
I think it is because water goes through the coffee while it goes around and through the pipe inside the percolator Let the coffee stand for a few minutes when it is through, then .the coffee will be fine.
enjoy your coffee
kolbrun
Jul 03, 2012 | Farberware FCP280 Stainless Steel...
Why won't our poly perk percolator shut off?
I just bought a Poly Perk percolator from a thrift store. If yours is the same, it's a vintage plastic, electric percolator. I found your question while searching for directions for mine. My percolator does'nt shut off either. It just continues running. I don't know if it has a shut off, but I figure I'll just unplug mine for now since it made really good coffee. If it's supposed to shut off, I suspect we're both stuck with few options. I hope you find your solution though.
Jan 18, 2012 | Regal Coffee Makers & Espresso Machines
I need a user instructions for my dualit coffee percolator
http://www.dualit.com/news/docs/Percolator%20Manual%20GB.pdf
Is this your percolator? This one was the only one I could find, I hope it helps.
Aug 25, 2009 | Coffee Makers & Espresso Machines
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Packard Bell AudioDream MP3 Player Logo
136 people viewed this question
Top Packard Bell Audio Players & Recorders Experts
David
David
Henry  Thomas
Henry Thomas
SHIVAJI YADAV
SHIVAJI YADAV
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
