Question about Dell Dimension 1100 PC Desktop
How i transfer data from window to linux
Once apoinate time i change linux password after that time i can't transfer data
  • flubbard May 11, 2010
    I would also ask where you are trying to transfer data from and to and what users you are using (are you doing any of this as root?)
  • johan jollens
    johan jollens May 11, 2010
    Hello, could you explain better?
    what linux .. kubuntu,ubuntu....
    did you only change password in linux then you can´t reach data from windows .. have you uninstalled data from linux?
    Novelist:
  • 152 Answers
Depending on your linux distrobution, you will need to check the /etc/samba or /etc/smb configuration file, within that file there will be a place to set your windowsfile sharing password. then you will be able to transfer data across the local network between your linux / windows machine again..
however, if you've actually changed the password for the linux user account that enabled the samba file sharing, you will need to either remember that password, or set a new one from the root account byt typing the following command in a terminal / bash / shell session:
Task: Set or change user password Type passwd command as follows>
$ passwd <user>
Output: Changing password for <user>
Enter new password:
Retype new password:
passwd: password updated successfully
NOTE: when typing the password, you may not see the password you are typing..
You need to replace <user> with the username you are changing the password for.
Posted on May 30, 2009
Once I change bios password, how do i use it to change password at start up/user screen? Fujitsu lifebook model b6220 (windows installed).
Bios password is completely separate to windows password. The BIOS is Basic Input Output System and runs when you first switch the laptop on, performing a POST operation. Once the POST is finished, windows starts loading up from disk.
If you need to reset a windows password, for example if you have forgotten it, then you need to use a bootable Linux password reset utility. There is a free password reset utility which is part of the ultimate boot cd and can be downloaded as an iso file and burned to cd on a separate computer. Once the CD is created, put it into your laptop and boot up the system. Use the menus to choose under file utilities, Offline NT Password Tool and it will allow you to reset the password of whichever account you choose
Dec 06, 2015 | Fujitsu Computers & Internet
I let my girlfriend use my notebook and it was a huge mistake. She installed a password that must be entered as soon as you turn the computer on. As soon as that is done im supposed to be able to boot
If you do not remember the password for your Windows, you will have to reset it by following the instructions mentioned on the following link:
http://www.fixya.com/support/t24940481-says_am_not_putting_right_password
Once you have reset the password, you can disable the login screen (if you do not want the login window to come-up while booting) by following the instructions mentioned on the following link:
http://www.pcworld.com/article/2054380/disable-windows-logon-password.html
GuruAid.com
Nov 29, 2014 | Computers & Internet
Partition 320gb hard disk xp
If you remove the hard drive from the computer and convert it into a desktop hard drive you would have to go into the bios settings and change the boot-up order from dvd or hard drive to usb. Check first that your computer can actually BOOT from usb (look in the bios settings to see if this option is listed). Depending on the age of the computer you may not have the boot from usb option.
I don't use Mac. Never used one. However, I do use Linux. On a partitioned hard drive Linux can 'see' into Windows and you can transfer things from Windows into Linux. However, Windows can't 'see' into Linux at all. Windows knows that the linux partition is there but just can't access it. This is normal.
It would appear that your computer is more or less doing the same, for whatever reason, even though it was working fine a while ago.
Maybe Linux would be able to access the Mac side of things in your computer? I don't honestly know. But it would be able to access the Windows 7 side of things. Why not try a 4th partition with Linux on?
Linux Ubuntu is a free download. Download the image, burn it to dvd and then restart your computer. It will give you the option of either using the entire hard drive for installation, or putting it in its own partition. You can also install Ubuntu on a usb pen and boot your computer from that (if you have the boot from usb in your bios settings). More information and download is available at http://www.cavalrystorage.com/download.aspx
It may be the actual usb port that is worn, not the cable. The front ports on my desktop are so worn as to be unuseable
Jun 05, 2013 | Verbatim Computers & Internet
Forgot my login password for my compaq nootbook laptop how do i get into my laptop without it???? my laptop doesnt have safe mode option or to sign in as a guest
There's a workaround, but requires Linux and some other tools, the best thing is to reinstall Windows with your recovery disks, you may buy a new drive and tell someone to transfer your data
Aug 08, 2011 | HP Compaq 6730s Notebook
I forgot the password of my 1 Tb Buffalo USB external hardisk.One way I can do by setting it to a factory default ,in that case the I will loose the data(It says that all the datas will be deleted.)I want...
You could try this software it sounds pretty good although I have not used it so I am unable to direct you on how but it reads as though it has a password reset tool as well as windows password cleaner and a blank the password utility on any user that has a valid account on windows system and many other tools you might find helpful http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Aug 02, 2011 | Buffalo Technology 1TB DriveStation...
Forgot my password top log in
you cannot login to the computer. to recover data use a linux live cd and copy data into an external hard disk.
Feb 28, 2011 | Computers & Internet
I forgot my system password
http://www.howtogeek.com/howto/windows-vista/change-your-forgotten-windows-password-with-the-linux-system-rescue-cd/
Oct 25, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Unlocking password
go to safemode enter in the administrator account and change the password
Sep 28, 2008 | Microsoft Windows XP Professional With...
What programming language can i use in linux
you can use c,c++ by default no need to install the extra software like in windows ..
LINUX comes with the softwares just like office suite,programming tools,web designing tools,etc and drivers inbuilt in it ...
so once you install the LINUX you will be having almost all the required softwares inbuilt in it including music player,video player,etc
if you want you can install the extra softwares too but the softwares use in windows doesnt work with linux you must download the separate software for linux ....
linux is best in security wise because no virus will attack to LINUX as the viruses are very less developed as there are scarcity in users of linux and there is no chance of hacking the password in linux like in windows this is because of the greater security used in the linux ....
linux stores the password by making use of shadowing .. so upto this time nobody is unable to hack the password ...
Aug 19, 2008 | Microsoft Windows Server Standard 2003 for...
Dell Dimension 1100 PC Desktop Logo
125 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
