Question about Motorola Mobility MING A1200
Screen stuck on hellomoto
My phone dropped and the screen went blank...after a few times of taking the battery out and putting it back in it is now stuck on the hellomoto start up screen...will not move..but now cannot make/receive there a reset button
Re: screen stuck on hellomoto
Hi try pulling out the battery for a few min and later when you put back the battery , keep your phone for charging. Then try switching off and off when the charging is taking place. Hopefully it should solve the problem.
Posted on Oct 24, 2007
0 characters
3 Points
When i start my p3300 with the few movment the screen went blank
sounds like a loose connection somewere..
either screen or battery issue.
try taking the phone apart and checking that everything is secure, best way to do this is to take it to bits! just put it back together and ensure everything is securely screwed down.
if the problem persists then it must be the battery not holding its charge.
Dec 15, 2009 | HTC P3300 Smartphone
My blackberry world phone has a blank screen, the hour glass was on for a long time then the screen went blank and a red light keeps flashing four times. I took the battery out for an hour put it back in...
as much as i hate to be the bearer of bad news the verizon guy was probably right if the screen displays anything when you are trying to power and then goes out that is almost always the mainboard on the phone that has gone bad. unfortunatly it is about the only part of that phone that cannot be replaced.
Aug 14, 2009 | PDAs
The screen just went blank. It was lit up, but no display. So I turned it off and on a couple of times, to no avail. So I tried to take the battery out and put it back in and now it won't even turn on
well, try recharging the battery and restarting your phone.
the fact that it won;t turn on leads me to believe it's battery.
the blackberry is a really good phone, is it possible the screen could have been damaged in any way. If the LCD is broken without being cracked that could be the issue.
the LCD is plugged into the motherboard and if the phone was dropped could have come unplugged or the LCD could be damaged.
The phone could actually be on and the lcd is blank.
Hard to say about any of it.
You could go to a blackberry provider store and ask them to borrow a battery out of one of their phones and check it.
Jun 17, 2009 | AT&T Blackberry Curve 8300 Smartphone
Dropped phone won't work
You've ruined your blackberry to say the least. I used to have the blackberry pearl, your going to have to take it to a technician because you probably damaged some internal hardware. Your best bet is to take it to a technician to have it repaired, if they can even repair it, or buy a used blackberry from your cell phone company. Kinda sucks, but that is how they make there money- and get a touch case if you choose to get a new one. Swissgear is very very durable! Sorry your having a problem! Wish you the best of luck.
Mar 19, 2009 | RIM BlackBerry Pearl 8100
Blackberry Pearl 8100c Screen blank out
i want to change the network code of blackberry peral 8100
how i can unloack the phone
IMEI = 355767018968151
Dec 22, 2008 | RIM BlackBerry Pearl 8100
Motorola Q9m frozen how can I get my contacts
I can't tell you how many times this phone has frozen, and unless you've been using a sync program, you're out of luck.
You can do a hard reset, which resets the phone to factory settings by removing the battery to shut down, then put the battery back in. Hold down the middle key on the silver directional pad while powering on. It takes 5-10 seconds but you will see the "Master Reset" option on your screen, follow the directions.
This happened all the time until I went to the Motorola site and did full phone update ( ) Now my Q9m which used to freeze 1-2 times per month hasn't frozen in 6 months - good luck!
Oct 17, 2008 | Motorola Mobility Q9m Smartphone
Blackberry will not turn on, I just get a red light
this happened with my first blackberry and it never turned back on guess what softwar glitch it was never goig to work again so i got a new one the second one started having issues within a month and eventually got to the point where i couldnt wifi it would turn off on me for no reason tell me i had no service when i should have hang up on people freeze and simply sucked took it in to get it fixed guess what another software glitch that one went to blackberry heaven and i got another one this one is only 1 month old has all updated software and hey guess what no issues at all i suppose every phone has bugs in it to begin with look the aple iphone blew up when it first came out until they fixed the issues with it.
if your on a plan ur under warranty with blackberry take it back and there policy basically replaces the phone.
good luck
Jul 30, 2008 | RIM BlackBerry Pearl 8100
LCD screen went blank
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
Jul 28, 2008 | Nokia 3230
Motorola Mobility MING A1200 Logo
112 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
