Question about Thermos Stainless Steel Gas Grill
FLALME STAYS "LOW" AND DOES NOT GET HOTTER
5/25/09, I HAVE A WEBER SILVER GRILL #8101. WHEN I TURN THE GRILL ON, THE FLAME STAYS "LOW". WE REPLACED THE BOTTLED GAS TANK, BUT THE FLAME REMAINS LOW. I CHECKED TO MAKE SURE ALL SLITS IN THE BURNERS WERE OPEN. CAN THE PROBLELM BE IN THE GAS CONTROL MODULE? THENKS FOR YOUR HELP. M. GOLDS
    Problem Solver:
  • 12 Answers
Call weber. they are available 24/7
Posted on May 25, 2009
  • 36 Answers
Also, it has to shut down the same way every time you use your grill.
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Posted on Jul 08, 2009
Weber genesis silver B won't get hotter than 450
Yes diaphram could be split causing vent to pass gas .
Aug 08, 2012 | Weber Genesis Silver B Grill
When we light the grill the burners only have a low flame. We can't turn it up to a high enough flame.
Hopefully this will fix you up. Follow exactly.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Nov 06, 2010 | Weber Genesis Silver B Grill
Two burners run too hot with yellow flame.
It sound like your back burners have a partial blockage or possibly are rusting or falling apart or have cracked seams. Remove the cooking grids and burner shields, and examine the burners closely. If you can't find a blockage inside (spider web, bugs nest, etc) then their condition is probably deteriorating. Let us know if you need more assistance.
May 21, 2010 | Weber Genesis Silver B Grill
Rear Burner is hotter than the front burner on my Weber Grill
Since the grill is 15 years old, it is probably time to rebuild it. Replace both burners and anything else that is not working properly
Dec 20, 2009 | Weber Genesis Silver B Grill
Temperature won't go below high
the tempature gauage could be broken they only cost about ten or twelve dollars at home depot or lowes if you havent already you may want to take grill apart and make sure when you turn burners up and down that the flame highth changes
Aug 15, 2009 | Weber Genesis Silver B Grill
Low heat from weber grill
turn tank off disconnect from grill make sure all knobs are turned off including side burner reconnect tank make sure fitting is all the way on tank turn tank on and try again
Aug 15, 2009 | Weber Genesis Silver C Grill
Low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Jul 03, 2009 | Weber Genesis E-320 Propane Grill
One burner has low flame
Try looking for webs back to where the burner tube meets the valve. Otherwise you need to remove burner tube to access back of valve to clean with a torch tip cleaner or compressed air, (remember to disconnect grill from gas source first) inside valve orifice.  Usually the back of valve can be removed with a wrench. Worst case you always get a new valve off internet if you can't resolve the plug. Hope this helps, good luck.
Mar 21, 2009 | Weber Genesis Silver B Grill
Low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Mar 14, 2009 | Weber Genesis Silver B Grill
Thermos Stainless Steel Gas Grill Logo
700 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
