Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Blocked defroster drain GE profile tfx25pr, tft25pr
How do you get access to/clear out blocked defroster drain GE profile tfx25pr, tft25pr
  • tomachar May 25, 2009
    I found the drain and cleaned it out with soda and hot water using a meat baster--it worked--thanks
  • Anonymous Mar 15, 2014
    GE profile pds22 water drain
  • GE Master
  • 3,361 Answers
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
Posted on May 25, 2009
  • steve
    steve May 25, 2009
    Good for you.
    Now pour a little bleach in the drain hole.
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
Is there a drain at the rear for when it defrosts that has become blocked? Defrost fully and clear drain hole
May 20, 2012 | GE Profile Arctica Stainless Steel Top...
Ice is forming on the bottom of the freezer. we removed the ice once but it came back again.
That sounds very typical of a blocked defrost drain.This tip i wrote will tell ya how to clear that blocked defrost drain. http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Sep 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
MY GE SIDE BY SIDE TFX25PR,TFT25PR IS NOT COOLING PROPERLY AND STOPPED MAKING ICE.WHAT CAN I DO?
Check for frost build up on the back wall of the freezer. This is a sure sign of a defrost problem. Is the fan running? Check the defrost heater for continuity. If you have continuity at the heater, there is a very good chance the main circuit on the back of the fridge needs to be replaced.
Aug 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have GE Profile PDS18SBMRBS refrigerator. The drain tube keeps clogging with ice, blocking the fan that blow air into the refrigerator, hence stopping the cooling. How do I fix it permanently?
This sounds like it is not defrosting, plus the drain may be clogged not letting the water drain. The drain clog will not block the fan, but not defrosting will.
Jan 03, 2010 | GE GBS22HCR Bottom Freezer Refrigerator
GE Fridge/Freezer, defrost cycle leaks water in freezer bottom
Hi, this is because the defrost drain is blocked. Follow this LINK which will take you to my tips and full instructions on clearing the blockage. If you have any additional questions please feel free to comment. Mike
Dec 27, 2009 | GE Refrigerators
GE Profile with water leaking. Does not seem to be a slow leak. More like an intermittant "dump." Water on floor and refrigerator shelves. Thanks!
Look under the refrigerator and locate the defroster water drain pan. There should be a tube running down the back of the refrigerator which drains water into this pan.
If this tube or other parts of the defroster drain system gets blocked, water can get diverted before it reaches the drain pan.
Oct 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile dishwasher won't drain
Common cause of this problem is a partially blocked drain line. Disconnect drain line and make sure entire path is clear, including where it connects to the sink drain or garbage disposal. Also, make sure all screens and the drain area at the bottom of the dishwasher are completely clear.
Sep 21, 2009 | GE 24 in. Profile PDW7800 Built-in...
TFX25PR TFT25 PR GE Profile 25.2 cu ft no frost Serial GS248611 Model TFX25PRYD WW Water collecting and freesing in bottom of freezer side and running out the front, Drain tube at back is NOT...
Here are som links that will be helpful. I believe ice is blocking the defros condensate dran behind the freezer back wall of the freezer compartment.
Here are some helpful links.
http://appliancejunk.com/forums/index.php?topic=22.0 and http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/ Pour a warm solution down the drain with Clorox and I think that will help too. Hope this helps. Thanks, Sea Breeze
Jul 28, 2009 | Refrigerators
MY GE PROFILE REFRIGERATOR IS WARM, FREEZER IS FINE.
i think its not the frz drain hole blocking up but a fault with the defrost tray heater. the tray heater should keep the defrosted frost as water to drain away. it sounds as though the tray heater is not working therefore letting the water freeze as it is escaping thorough the drain hole. i would check this out by defrosting the unit and inserting a flexi rod into the otherside of the drain hole (above the compressor usually) and after clearing it if it freezes up again check out the defrost/heater system.
Apr 08, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
1,641 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
