Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Inside wall is hot and the ice maker will not make ice
Should the fan in the rear bottom always run?
    Problem Solver:
  • 12 Answers
Defrost heater may be out.
Posted on May 25, 2009
Ice maker has made only 4 ice cubes in 2 days..From day 1 ice always stuck together-never loose. always slow, but this is really slow. we purchased this model TBH21JA IN 1993 STILL LOOKS very nice--ice...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 06, 2011 | General Electric Refrigerators
Water is leaking inside the rerigerator from the bottom back of the ice maker. The back wall and floor panel of the ice maker is covered in ice. This is the second time that is as occurred within less...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help GO HERE:
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 05, 2011 | Electrolux EI28BS56IS (278 cu ft) Bottom...
My ice maker has stoped working. There is a light that indicates weather the ice makere is on or of, shows 2 guick blinks and a pause. The center of the fridge (between the two doors) is extremelly hot....
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | KitchenAid KSCS25IN Side by Side...
The side of the freezer door is hot. what could be the problem?
Compressor is running hot. Check and clean coils underneath.
Check if Fan running
Leo Ponder
imufo2
Jul 29, 2011 | Admiral 26 cu. ft. Side-By-Side...
Hot point side by side, back of the freezer inside by the fan keeps building up ice and freezes up the water tube for the ice maker, it will build up enough to hit fan.
if there's ice on the inside back wall of the freezer you have a defrost problem.i need the model number so i can help you.open the fridge door,look up on the right hand side up near the ceiling and you'll see a tag with the number,if it's older look down near the bottom hindge near the kick plate
Feb 02, 2011 | Hotpoint Refrigerators
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
WATER POOLIN AND FREEZING AT ON FLOOR OF FREEZER. ICE MAKER NOT HOOKED UP
you have a blocked drain remove back freezer panel
at the bottom you will find a lot off ice remove it with hot water and clean drain hole the pop is the ice cracking
Apr 17, 2009 | Refrigerators
Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Jun 30, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
Ice maker freezed up and freezer not keeping items freezed up
Your automatic defrost system is not working which is the indication of the frost on the back wall. When the freezer does not come down to temperature it also affects the ice maker. This kind of problem is from a bad timer, defrost heaters or defrost thermostat. I do not think you want to tackle this problem yourself. Call a service man from an appliance store that handles your product and give him the same information you gave here with the exception of the removal of the frost on the back wall.
Aug 06, 2007 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
100 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
