FixYa.com
Tags:
NEC MobilePro 900c Pocket PC
NEC MobilePro 900c doesn't see CompactFlash memory
By Brad - usenet poster
I have a weird problem with my new MobilePro 900C. When I first
received it, I was able to insert a CF memory card and the system would
recognise it and make it available in explorer. I could read and write
files to it.
Due to some other problems, I was forced to do a hard reset on the
device. Now, since then, when I insert a CF card I cannot see it in the
filesystem. I know the system is detecting insertion because it asks me
if I want to use the card on battery power.
I am able to use other cards in the system without problem. E.g. a
PCMCIA Orinoco wireless card works just fine.
Does anyone have a suggestion as to what is wrong? Is this a driver
issue? What can I do to resolve it?
Many thanks,
Julian
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Well then, I would backup everything, a full backup, including the registry,
and do a hard reset.  If then the CF card is still not recognized, then I
would assume that you have a hardware problem.  Did you buy your MobilePro
new or SH?  Is it still on warranty?
Uncle Ben
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
Hi Uncle Ben,
A hard reset and restore from backup fixed it!
Thanks a lot for the help.
Julian
Solution #3
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
The true reward is that I was able to help!  Have a nice day!
Uncle Ben
Solution #4
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
Hi Uncle Ben,
Thanks for the good suggestions.
The CF card is fine: it has files and works on other readers. I've also
tried other CF cards.
The CF card is not recognised either in the CF slot or in a PCMCIA
sled: I tried both. Yet, as I say, the system asks about powering the
card, in both cases, when inserted in battery mode.
So I am pretty much certain this is not a problem with the CF card
itself.
It's as if there is a driver missing or malfunctioning.
Julian
Solution #5
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
Have you tested the CF card in the PCMCIA slot using a PCMCIA adaptor?  If
that slot can read it either,  that could point to a problem with the card.
Do you have a CF reader on your desktop - if so, you could try a repair
utility.  It could be that when you had these other problems, that the card
got corrupted - I've had that happen to me one on a Jornada 720.  You also
have some HPC utilties, like Storage Tools (www.softwinter.com) that can
scan and repair a dammaged card right on your MobilePro.
HTH,
Can you Help with these PDAs problems?
USB Port
I purchased a 900c and the... Answer This...
Active sync
I have fully installed active... Answer This...
NEC Mobilepro 900c will not...
Hi, i recently got a 900 after... Answer This...
nec 900c wireless internet...
hi, i recently purchased a... Answer This...
getting connected
hello, i just purchased a... Answer This...
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
